04-22-2014, 07:49 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: Afghanistan
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | 808 touch doesn't work and its screen lights are always on metal shield from the board to change charge IC but didn't solve than changed power IC still same than he find out that its charging base was wrongly replaced and charging problem solved but got a new problem that touch doesn't work screen lights are always on . Please guide how to solve it and what might caused the problem ? P.S touch is OK and it was working before removing the metal shield from the board WBR |
04-23-2014, 07:05 | #3 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote:
Nokia 808 PureView touchscreen try to trick the second picture below first rehot touchscreen supporting components if it is still as before: try changing its touchscreen check its touchscreen path only thank button | |
The Following User Says Thank You to d-Artigo For This Useful Post: |
