E66 keypad strange problem e66 is giving strange keypad problem.....when i press any key another key will work with the first key means when i press 1 then 1 and 3 come on the screen 2 is ok.if i press 4 then 4 and 5 appear 6 is ok.when i press 8 it appear 8 and 9 and 7 is ok........plz suggest me to solve this problem. NOTE= THE UPPER KEYS ARE WORKING FINE ONLY LOWER IS PROBLEM. BEST REGARDS |
change the sim and mmc soket completly, it wil work fine tested by me 100% |
what sim ic and mmc!!!?? im sure before its water dameged just change keypad ic and check all parts according to keypad connection theres a shorted there but all i repair done same your problem is keypad ic only |
can u tell me keypad ic location |
Check side volume key. Sometimes are locked pressed one from this keys. |
check the small flex cabel between moterboard an sim reader , or change all(sim reader with mmc soket) |
i tried it working 100% good thank u :) |
Change main flex cable.Good luck |
plos Quote:
dear sim & mmc assmbly conected with side volume switch ok............ |
I tested by unplucking sim and mmc socket. Works 100%. Thanks |
plez any body help me i have e66 it is mmc,sim card,side key not work i change sim socket but still not work plez plez help me.......... |
Great Job .............Thanksss.......... |
nokia E66 hardwere solution one exe chek link nokia E66 hardwere solution one exe |
bro complet change new sim,mmc and side volume shoket pro 100% solve |
