Old 09-15-2009, 19:28   #1 (permalink)
khm050's Avatar
Member: 133201
Thanks Meter: 74
E66 keypad strange problem
e66 is giving strange keypad problem.....when i press any key another key will work with the first key means when i press 1 then 1 and 3 come on the screen 2 is ok.if i press 4 then 4 and 5 appear 6 is ok.when i press 8 it appear 8 and 9 and 7 is ok........plz suggest me to solve this problem.
NOTE= THE UPPER KEYS ARE WORKING FINE ONLY LOWER IS PROBLEM.
BEST REGARDS
The Following 3 Users Say Thank You to khm050 For This Useful Post:
Old 09-15-2009, 20:13   #2 (permalink)
Member: 42739
Thanks Meter: 7
change the sim and mmc soket completly, it wil work fine
tested by me 100%
The Following 3 Users Say Thank You to kaieshafid For This Useful Post:
Old 09-15-2009, 20:40   #3 (permalink)
jhoesteve's Avatar
Member: 539557
Thanks Meter: 193
what sim ic and mmc!!!??
im sure before its water dameged just change keypad ic and check all parts according to keypad connection theres a shorted there but all i repair done same your problem is keypad ic only
The Following 4 Users Say Thank You to jhoesteve For This Useful Post:
Old 09-15-2009, 20:45   #4 (permalink)
khm050's Avatar
Member: 133201
Thanks Meter: 74
can u tell me keypad ic location
The Following User Says Thank You to khm050 For This Useful Post:
Old 09-17-2009, 19:29   #5 (permalink)
bossko's Avatar
Member: 17761
Thanks Meter: 91
Check side volume key. Sometimes are locked pressed one from this keys.
Old 09-18-2009, 21:47   #6 (permalink)
Member: 42739
Thanks Meter: 7
check the small flex cabel between moterboard an sim reader , or change all(sim reader with mmc soket)
Old 10-17-2009, 20:13   #7 (permalink)
RAHMAN007's Avatar
Member: 915625
Thanks Meter: 47
tested by me 100%
i tried it working 100% good
thank u
Old 10-17-2009, 21:01   #8 (permalink)
Don_R's Avatar
Member: 256801
Thanks Meter: 49
Change main flex cable.Good luck
Old 11-15-2009, 12:30   #9 (permalink)
Member: 699417
Thumbs up plos
dear sim & mmc assmbly conected with side volume switch ok............
Old 03-19-2010, 09:18   #10 (permalink)
Member: 458909
Thanks Meter: 33
I tested by unplucking sim and mmc socket. Works 100%. Thanks
Old 03-26-2010, 00:20   #11 (permalink)
Member: 989163
plez any body help me i have e66 it is mmc,sim card,side key not work i change sim socket but still not work plez plez help me..........
Old 05-13-2010, 02:29   #12 (permalink)
Member: 458884
Great Job .............Thanksss..........
Old 07-24-2010, 09:01   #13 (permalink)
javedsf's Avatar
Member: 811013
Sonork: 03468717163
Thanks Meter: 744
[IMG]http://**********.pk/thumbsup007/viu1279958465w.jpg[/IMG]
The Following 2 Users Say Thank You to javedsf For This Useful Post:
Old 07-24-2010, 09:06   #14 (permalink)
javedsf's Avatar
Member: 811013
Sonork: 03468717163
Thanks Meter: 744
nokia E66 hardwere solution one exe
chek link
The Following User Says Thank You to javedsf For This Useful Post:
Old 07-24-2010, 09:37   #15 (permalink)
Tabrez1's Avatar
Member: 1343156
Thanks Meter: 45
bro complet change new sim,mmc and side volume shoket pro 100% solve
1650 keypad strange problem sphameed Nokia Hardware & Hardware Repair 16 04-12-2010 09:48
3230 keypad strange problem lavlesh jain Nokia Hardware & Hardware Repair 7 12-17-2009 15:42
v3i keypad strang problem bhuttagee Motorola Hardware Repair 2 09-29-2008 05:21
5300 keypad strange problem lakshmireddy Nokia Hardware & Hardware Repair 3 07-21-2008 09:29
v980 keypad strange problem servicemobeliks Motorola Hardware Repair 1 07-17-2008 22:48
Page generated in 0.22435 seconds with 10 queries
