Old 07-06-2010, 21:35   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
e71 show blue screen than nokia logo and restart
nokia e71 show blue screen than nokia logo and restarts 4 to 5 times and finally blue screen hang
history of phone
when customer brings this set it sometimes power on sometimes not and power on when insert charger
action taken:
remove power switch and make it short
full flash
rehot betty and avilma after that set completely dead(on power supply takes 01 amp when press power button and not connected on sw)
change betty and avilma from working set
reball rap and flash
finally one of my friend naveen basa give me jumper solution which i made than set comes onto power but startup with blue screen than nokia logo and restarts 4 to 5 times and stuck on blue screen
i aslo full flash but still same
here is the picture
The Following User Says Thank You to HUM For This Useful Post:
Old 07-06-2010, 21:57   #2 (permalink)
Member: 1339787
Sonork: robert_n1ke
como lo liberar esto mobiles nokia 5800 xpress musick ayudame por favor contacts my id [email protected]
The Following User Says Thank You to armany009 For This Useful Post:
Old 07-07-2010, 09:12   #3 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
any solution mates ?
Old 07-07-2010, 10:01   #4 (permalink)
Member: 852547
Sonork: 100.1621506
Thanks Meter: 40
Flash the Phone using PMM erase file...
Then Flash it with latest data pakage..
Old 07-07-2010, 12:39   #5 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
i did but still same ?
Old 07-07-2010, 15:51   #6 (permalink)
GSMTURBO's Avatar
Member: 479496
Sonork: 1592751
Thanks Meter: 404
change betty ic same time betty ic problem in bule screen post result
Old 07-08-2010, 02:16   #7 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
sir r u sure its betty problem?
Old 07-08-2010, 21:39   #8 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
here is selftest
Phone Type: RM-357
SW version: V ICPR71_09w47.3 09-02-10 RM-357 (c) Nokia
ID Test name Startup Result
88 TAHVOINT Y passed
46 UEM_CBUS_IF Y passed
3 EAR_DATA_LOOP Y !failed !
12 SIM_CLK_LOOP Y passed
13 SIM_IO_CTRL_LOOP Y passed
33 SIM_LOCK N passed
93 SECURITY N passed
90 PWR_KEY N !not ready
2 CURRENT_CONS N passed
20 BACKUP_BATT N passed
56 SLEEPCLK_FREQ N passed
96 HOOKINT N passed
101 BTEMP N passed
108 EXT_DEVICE N passed
86 CDSP_RF_BB_IF N passed
83 CDSP_RF_SUPPLY N passed
85 CDSP_TX_IQ N passed
74 CDSP_TXC_DATA N passed
82 CDSP_PWR_DETECTOR_BIAS N passed
79 CDSP_RX_PLL_PHASE_LOCK N passed
80 CDSP_TX_PLL_PHASE_LOCK N !not ready
75 CDSP_WCDMA_TX_POWER N !not ready
81 CDSP_RX_IQ_LOOP_BACK N !not ready
77 CDSP_GSM_TX_POWER N !not ready
6 IR_LOOP N !not ready
7 KEYBOARD_STUCK N !not ready
21 LPRF_IF N !not ready
22 CAMERA_IF N !not ready
37 SEC_CAMERA_IF N !not ready
44 LPRF_AUDIO_LINES N !not ready
59 MAIN_LCD_IF N !not ready
71 BT_WAKEUP N !not ready
72 WLAN N !not ready
92 BT_WLAN_COEXISTENCE N !not ready
42 RADIO N !not ready
Old 07-10-2010, 13:18   #9 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
still no suggestion mates?
Old 07-11-2010, 15:52   #10 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
anyone solve this type of problem?
Old 07-19-2010, 05:06   #11 (permalink)
..:::YMG:::..'s Avatar
Member: 667126
Sonork: 100.1651201
Thanks Meter: 229
Change the Bluetooth ic and flash it again......post the reasult
Old 07-19-2010, 07:12   #12 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
have you try ENO file???
bro try to flash E71 blank file in mx-key mcu log
just select in mcu this file,,,,,,,,,,,,
i have done hope ur also work it
link:::http://www.usaupload.net/d/iq55pnip17v
The Following User Says Thank You to gsmshare For This Useful Post:
Old 11-06-2010, 22:32   #13 (permalink)
Member: 601591
Thanks Meter: 86
hi my own sollution is just remove all the cover gently,remove mic cos of damage,then soak it inside fuel or wash it very well with fuel now dry it with bulb or rehot it very light.so dont look at this as simple sollution pls try and post result.
Old 07-14-2013, 18:27   #14 (permalink)
Member: 1270839
flash it with blank ppm file.
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
Page generated in 0.28016 seconds with 10 queries
