Old 08-18-2005, 13:46   #1 (permalink)
noi
noi's Avatar
Member: 49103
Thanks Meter: 45
nokia 7610 display
holla!
my n7610 can call but no display, the LCD is good..any one has pic or solution for this? thanks in advance.
Old 08-18-2005, 14:34   #2 (permalink)
kardelen gsm's Avatar
Member: 133173
Thanks Meter: 119
check Lcd connector and change Z402...........REGARDS
Old 09-07-2005, 12:52   #3 (permalink)
Member: 62509
Thanks Meter: 5
hi
Hi,i have similar problem,backlight is enabled but no image appears on display only interferences and snow, conector is ok, display is ok....
Old 10-02-2005, 04:35   #4 (permalink)
Syed's Avatar
Member: 19979
Thanks Meter: 116
use search button. u will find wat u need !!
WBR
Syed
Old 12-23-2005, 02:13   #5 (permalink)
Member: 36741
Thanks Meter: 5
hi syed plz send me i've also in same situation display and connecter is ok but no display how can i find my solution reply soon
and remember some also i can't make call and can't receive this fault happened by bigshock sorry for my bad english
Old 01-08-2006, 06:52   #6 (permalink)
sivaprasad's Avatar
Member: 4853
Thanks Meter: 9
7610 no display check
respected members,
can you please check digital multimeter and put diode mode --l>-- check all pins reading from top left
o o 1 l l l l l l l l l l l l 12
spk connector 13 l l l l l l l l l l l l 24
lcd connector
pin 1-with the help of multi meter --l>--mode 475 to 650 reading good no reading check emi filter ic open 000reading short.
pin 2- 550 to750 in beetwen them
pin 3- nc
pin 4- 550 to750 in beetwen them
pin 5-ground
pin 6-550 to750 in beetwen them
pin 7- ground
pin 8-550 to750 in beetwen them
pin 9-ground
pin 10-ear piece
pin 11-ear piece
pin 12 -black light -ve
pin 13-ground
pin 14-550 to750 in beetwen them
pin 15-ground
pin 16-550 to750 in beetwen them
pin 17-ground
pin 18-550 to750 in beetwen them
pin 19-550 to750 in beetwen them
pin 20-ground
pin 21-lcd +
pin 22-331
pin 23-ground
pin 24-500
Old 12-16-2010, 11:44   #7 (permalink)
Member: 1415114
frens, I have Nokia 7610 which accidentally I dropped into my bucket. Then the LCD light did not work. I took it to a repair center where they did jumpering. Now, when the battery is inserted, the LCD just turn on. The Power button does not function at all. Kindly help me......
Khawzawlpa
Old 12-16-2010, 13:35   #8 (permalink)
ARIF GIGANI's Avatar
Member: 890965
Sonork: 100.1605360
Thanks Meter: 180
nokia 7610 display problem noi Nokia Hardware & Hardware Repair 10 05-20-2010 13:40
nokia 7610 display blinking i will flashing but no use please help me immediatly prakash40 Nokia Hardware & Hardware Repair 2 03-14-2010 18:25
NOKIA 7610 display problem common Nokia Hardware & Hardware Repair 2 02-24-2009 06:19
Nokia 7610 display blinking sajithcellular Nokia Hardware & Hardware Repair 6 02-17-2008 12:40
Nokia 7610 Display light not working BVC-PROJECT Nokia Hardware & Hardware Repair 9 11-27-2006 15:10
Page generated in 0.20598 seconds with 9 queries
