11-12-2009, 17:42 | #1 (permalink) |
Registered User Join Date: Jan 2004
Member: 49677 Status: Offline Thanks Meter: 53 | Easy way to check LCD light fault in some bb5 phones u can use this sequence steps 2 know what cause the lcd light fault Before we begin we should know that lcd leds need high voltag (Usually 12~16 v) but our source (battery voltage 3.7 v) so we use Special electronic Components 2 have this high voltag needed 2 the leds of the lcd (usually dc-dc converters) Now, let's start Suppose that we have a bb5 phone with lcd light fault (let us say e70) i use e70 to show u the easy way 2 find lcd light circuit Because this device is not common and We usually dont know where is the lcd light circuit or driver step 1 open e70 shematic and Search 4 pwm (see pic) Note 1 pwm is Pulse-width modulation (it is the controler in dc-dc converters voltag switching) pwm keep voltage constant from the first search Result we found our controler(pwm) and our lcd light driver (n2301) see pic driver location in the mainbord the lcd light driver have 8 pins only 4 of them needed 4 tracking lcd light pb(often) see pic step 2 check the vout pin voltage in the Component that conected 2 this pin (in our case Capacitor c2315) also this voltag should be in lcd conector (pin 20 in e70) there is also low voltage (often 0.5 v or lower) this low vol is fb feedback (in pin 21 lcd conectore and in r2304) if the vout vol is missing we should move to next step step 3 check the en pin (enable) this pin give the led driver the authorization to start voltage switching sometimes there is test point(in our case j2309) we can check en vol(usualy 1.8v when light active) in our case the test point is near led driver(see pic) if the en voltage is not ok we have 2 change the Component conected to en pin in our case thavo if the en voltage is ok we move 2 next step step 4 check vdd pin (some times it called vin pin) this pin supply the lcd driver with vbat voltage (in our case check c2314) if every thing is ok move 2 next step step 5 check ind pin (Induction) this pin supply the lcd driver with vbat voltage Through coil (in our case l2304) we check the coil 2 test this pin many Other bb5 phones can be checked in Similar way such as: 3250-3109-3110-5200-5300-5700-6125-6131-6133-6136-6151-6233- 6270-6280 6290-6500-6555-6630-6680-6681-7370-7390-7500-e50-e60-e61-e65- e70-n70-n71 n72-n73-n76-n77-n80-n81-n82-n91-n93-n95-n770 this is only one way but it is the most common way sorry 4 bad eng hope it is clear and Useful B.R MAGDY2 |
The Following 20 Users Say Thank You to MAGDY2 For This Useful Post: |
11-15-2009, 15:36 | #3 (permalink) |
Freak Poster Join Date: Sep 2008 Location: UAE
Member: 870376 Status: Offline Thanks Meter: 27 | THank you for your information vey useful. in case of me, n70 j2309 has not any vol even after changing TAhvo. whats the problem? |
The Following User Says Thank You to dfs3ds For This Useful Post: |
11-15-2009, 19:49 | #5 (permalink) |
Member: 870376 Status: Offline Thanks Meter: 27 | Thank you master, it worked. I had not any output in c2315, and now I have 0.33 v. but I am wonder why my main problem yet exist; when the phone is switched on by power supply, the current starts from 32 goes to 25 and stops there for about 4 second and then become off (0.00). no light both in Lcd and Keypad. Please Help if you know the solution. the phone problem was white screen and I repaired it by changing display filters and making jumper. this solution worked pretty nice just for about 4 hours and now I have this problem: no light, hang and off. |
11-16-2009, 06:55 | #6 (permalink) | |
Member: 49677 Status: Offline Thanks Meter: 53 | Quote:
remove jumer the phone problem was white screen what kind of white screen some times phone work well without sim card with sim card it work and after a time its hange or go into white screen this fault is smps or omap fault (specialy if the phone fall or water dameg) tell me about phone history | |
The Following User Says Thank You to MAGDY2 For This Useful Post: |
11-16-2009, 14:40 | #9 (permalink) |
Member: 870376 Status: Offline Thanks Meter: 27 | Dear master, the phone got white screen while his owner was working with it. when he brought it to me, the phone display had white screen, but yet you could hear the sound of keypad beep while pressing them, you even could hear the ring sound when there was a call. by changing display filters and making this jumper (( http://www.4shared.com/file/15147214...ite__hang.html )), the phone recovered and the problem solved. there was no more white screen and the display was ok, but the display was a bit blinking. the phone was ok just for about 4 hours and then the phone hanged while the phone was on, after restarting the phone it became ok but after 1 min it hanged. after restarting the phone the phone did not boot up, it was just hanged white screen. and at this moment the problem is blank display ( no light at all, both in key pad and screen) , hang ( you cannot see the nokia logo), and off ( when you power on, the current starts from 32 comes to 25 and then it becomes 0.00 (off). Your have done a great work by discribing the scematics, Please continue. Last edited by dfs3ds; 11-16-2009 at 14:46. |
11-16-2009, 15:26 | #10 (permalink) |
Member: 49677 Status: Offline Thanks Meter: 53 | did u try full flash do check with jaf and post if the check is ok try full flash and post log the custmer said what they always said nothing hapen what do you see in phones board |
11-16-2009, 20:44 | #11 (permalink) |
Member: 870376 Status: Offline Thanks Meter: 27 | here it is. check with jaf: APE Boot Data: Asic ID: 17100701 Asic Mode ID: 00 Asic Public ID: 5662AB7AFC58A325A9D21F35E39ADA40C131B62A HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 CMT Boot Data: Asic ID: 000000010000022600010006000C192101002200 Asic Mode ID: 00 Asic EM ID: 00000352 Asic Public ID: 1DD000044DBD58518F444BACFCE2FFD0CD5C62BD HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000 ROM ID: F28A211FCEA7B19D Error finding cmt boot file... I think it is not ok to flash it. while erroring : Setting FLASH MODE Error finding cmt boot file... Failed to backup CRT... ufs check: 1ST BOOT : C0,0C [Rm-84] [2.0.8.0] OMAP ID : 17100701 OMAP MODE : 00 OMAP PBID : 5662AB7AFC58A325A9D21F35E39ADA40C131B62A OMAP HASH : 2C05369F57CC3C4CF9E783E83D9B512B OMAP ROID : AB5E4ADB27A06946 RAPx ID : 000000010000022600010006000C192101002200 EM 1 ID : 00000232 EM 2 ID : 00000352 RAPx PBID : 1DD000044DBD58518F444BACFCE2FFD0CD5C62BD RAPx MODE : 00 RAPx HASH : E9EFF4BFAA5393217CA6B17755FC3E14 RAPx ROID : F28A211FCEA7B19D CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv2_2nd.fg, Ver: 1.21.0 00000000: 02 00 00 00 00 F1 72 ......r ERR: CMT 2ND Boot CMT 2ND CERT Mismatch Rebooting Mobile |
11-16-2009, 21:06 | #12 (permalink) | |
is the flash ic protected this is flash ic pb maybe it is flash ic voltage supply(retu) ur fault is clear cmt fault means flash ic some times it is retu or rap3g but i think it is flash ic (most of the time) maybe overheating led driver dameg protected cmt flash near it b.r | |
11-17-2009, 05:35 | #14 (permalink) |
Freak Poster Join Date: Sep 2008 Location: +060146324283 . Malaysia Age: 39
Member: 860925 Status: Offline Sonork: Now I'M Malaysia Thanks Meter: 294 | Thanks Bro Nice Post .................... |
The Following User Says Thank You to billal1050 For This Useful Post: |
Easy way to check shorting in nokia phones | digitized | Nokia Hardware & Hardware Repair | 445 | 11-29-2023 21:29 |
..:: Easy way to check Any point, Is it connected or No (Saif-Tc) ::.. | saiftc2 | Nokia Hardware & Hardware Repair | 33 | 09-23-2011 00:46 |
Easy way to check Iphone its 3G or 3GS !! | kmaxmax | iPhone 2 / iPhone 3G / iPhone 3GS | 15 | 02-24-2011 21:12 |
Easy way to check shorting in nokia phones | transpirit | Nokia Hardware & Hardware Repair | 2 | 11-18-2009 04:56 |
Any easy way to check modem on a Jailed iphone 3Gs? | blaiseid | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 10-07-2009 21:41 |
