Old 03-15-2009, 04:43   #76 (permalink)
That'sme's Avatar
Member: 228871
Thanks Meter: 43
Originally Posted by manzoore elahi View Post
hai this is manzoor please will u do me one favor please i am using nokia 6600 model actually what happen camera is not working when i take a snap means this message is coming temporary over load when i open gallery means i takes 5 mintues or more time to open i am using memory card only 64mb i done format by pressing *3 call button and on/off switch format is completed and i done format mmc card also but 1 or 2 snaps again it get same problem so it better to do flash or any another problem is that and recently i done format after 3 days now it is working when i open blue tooth means again it is going and all are opening but songs in the mmc card is not playing when i open realplay it shows no data but i open file manager in that its showing the songs but unable to play why please please solve my problem as soon as possible bcoz its my fever ate pice and 1 more thing u r frm and is their espert in hyderabad to solve my prob did u have any i dea please solve my prob thanking you
Simply Rehot the Bluetooth Ic ur problem would be solved...
Old 03-15-2009, 18:09   #77 (permalink)
Member: 610630
Thanks Meter: 37
Originally Posted by Harmandeep45 View Post
bro i have an problem with 6120-c , i flashed that mobile once but it get stop after the last stage of rebooting and i try it again the phone the phone never get flahed can u help me it says
cant sync with phone , i even cheack other cabel but same .
one thing more it was dipped in water
please helpppppp
try to with usb cable 100000%ok
After ok give thankes.
Old 03-20-2009, 09:19   #78 (permalink)
rafiqcell's Avatar
Member: 979016
Sonork: 1592061
Thanks Meter: 150
I have 3110c full short and cmt err.
already itry by using this solution but
no result same........what can[B
i do? plz help..........[/B]
The Following User Says Thank You to rafiqcell For This Useful Post:
Old 03-26-2009, 09:14   #79 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
6630 offline mode plz. help me CHANGE SIM IC PHONE OK
The Following User Says Thank You to panipat For This Useful Post:
Old 03-26-2009, 09:22   #80 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
have a n 70 its battery backup is only 16 hrs standby wats the problem is there any shorting NEW VERISION FLASH ONLY
Old 03-26-2009, 09:26   #81 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
camera is not working when i take a snap means this message is coming temporary over load when i open gallery means i takes 5 mintues or more time to open i am using memory card only 64mb i done format by pressing *3 call button and on/off switch format is completed and i done format mmc card also but 1 or 2 snaps again it get same problem so it better to do flash or any another problem is that and recently i done format after 3 days now it is working when i open blue tooth means again it is going and all are opening but songs in the mmc card is not playing when i open realplay it shows no data but i open file manager in that its showing the songs but unable to play why please please solve my problem as soon as possible bcoz its my fever ate pice and 1 more thing u r frm and is their espert in hyderabad to solve my prob did u have any i dea please solve my prob thanking you CHANGE BLUETOOH MODUL OK
Old 03-31-2009, 23:03   #82 (permalink)
Member: 999360
Thanks Meter: 3
Post N73 Nokia
i wanna ask u compelet blue light not display no incoming not out going so plz tell me about this problem
The Following 3 Users Say Thank You to Tasdeeqmuhammad For This Useful Post:
Old 04-05-2009, 03:25   #83 (permalink)
Crazy Poster
Member: 543613
Thanks Meter: 6
very very very usefull thread thank you very much
Old 04-14-2009, 05:59   #84 (permalink)
Member: 1002728
Thanks Meter: 2
2600c keypade
2600c keypad problems pls.e help me
The Following 2 Users Say Thank You to pawanmau For This Useful Post:
Old 04-20-2009, 05:19   #85 (permalink)
Member: 953337
Thanks Meter: 6
hi dear friends i have no idea of LG270 sim ic plz help
[email protected]
Old 04-20-2009, 18:20   #86 (permalink)
Member: 232244
thanx sir you do will
Old 05-03-2009, 07:46   #87 (permalink)
Member: 445578
Thanks Meter: 440
change youe galary ic (bluetuth module) then must be solved this module work for gelary open,camera ,blutoth,file menager etc.
Old 05-06-2009, 09:01   #88 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
Originally Posted by mobileland139 View Post
pls can some one pls help me with the solution for nokia 3110c blank sreen ps
bhai change two lcd ic ............
Old 05-06-2009, 09:06   #89 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
Originally Posted by taxila_77 View Post
hi friends i have 6280 when i open camra the masage come stand by mod and phone hang..........i m to much worry sadeed
bhai camra ok hai toooooo rebool cpu ok
Old 05-10-2009, 14:44   #90 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
check shoting in nokia 1680 classic.....
1..remove this coil mark in (1)..if u want to check the light ic is short....
2..remove this v.camdig ic n3301 mark in (2)..if u want to check the v.camdig maker ic ..this v.camdig maker ic got +b from batery....to make v,cam for camera.....
3..remove ringer ic mark in (3)..if u want to check shoting remove it and check if shoting is gone replace it because ringer ic also got +b volt from battery....
4..remove the pf n7700 mark in (4)...if u want to check is pf is short remove it and check shoting...if it is shot then replace it...
5.. check vibrator it also got +b...remove it to check shoting....
6..at end check the power ic and remove it to check shoting is there or not...
all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic ....
wbr..
..:Preet:..
The Following 6 Users Say Thank You to digitized For This Useful Post:
Page generated in 0.21553 seconds with 10 queries
