06-19-2010, 07:51 | #244 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Cel_Phon - M.B.Din
Member: 328187 Status: Offline Thanks Meter: 1,687 | MR . digitized sir plz upload here a compleat schematic of nokia 2330 the avail able diagram is not compleat(missing some area) but i now u have compleat schematic......plz upload i will thank full to u |
06-20-2010, 05:47 | #245 (permalink) | |
Freak Poster Join Date: May 2010 Location: with~predators Age: 38
Member: 1312914 Status: Offline Thanks Meter: 111 | Quote:
on hwk support the 2330 service manual of l3-4 is available it is about 54mb... | |
The Following User Says Thank You to chipset experts For This Useful Post: |
06-20-2010, 05:50 | #246 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | Quote:
RapidShare: 1-CLICK Web hosting - Easy Filehosting | |
The Following User Says Thank You to digitized For This Useful Post: |
06-20-2010, 09:43 | #247 (permalink) |
Member: 328187 Status: Offline Thanks Meter: 1,687 | thanks a lot............. nokia 2330 2323 auto shutdown solution here http://forum.gsmhosting.com/vbb/f148..._phon-1027716/ |
06-21-2010, 09:20 | #249 (permalink) |
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | check shorting in nokia 2220s rm-590.......new....... 1..remove the pf n7700 mark in (1)...if u want to check is pf is short remove it and check shoting...if it is shot then replace it... 2..remove ringer ic n2150 mark in (2)..if u want to check shoting remove it and check if shoting is gone replace it because ringer ic also got +b volt from battery.... 3..remove this coil l2401 mark in (3)..if u want to check the light ic n2400 is short.... 4..remove this v.camdig ic n3301 mark in (4)..if u want to check the v.camdig maker ic ..this v.camdig maker ic got +b from batery.....to make v,cam for camera..... at end remove uem clite ic this is power ic based on new tecnology and differ from uemclite which are placed in nokia 2330,2680,7100.... all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .... br, digitized |
The Following 14 Users Say Thank You to digitized For This Useful Post: |
06-22-2010, 08:18 | #251 (permalink) |
Freak Poster Join Date: Mar 2010 Location: pakistan & uae
Member: 1251098 Status: Offline Sonork: 100.1615825 Thanks Meter: 32 | 1202 key pad problem...insart sim set key pad is ok if inter sim key pad is no keys work (send.down.clea and 8) plz heip me urgent .i am chang keypad ic and flash but same falt |
06-24-2010, 17:08 | #253 (permalink) |
Freak Poster Join Date: Feb 2007 Location: IN GSM World
Member: 447009 Status: Offline Sonork: 100.1591307 Thanks Meter: 35 | Bro, Need Nokia 6280 board shorting solutions. Thanks in advance. Br Libran_s26 |
The Following User Says Thank You to libran_s26 For This Useful Post: |
06-26-2010, 05:47 | #254 (permalink) | |
check this link.... http://forum.gsmhosting.com/vbb/3456539-post13.html | |
07-09-2010, 08:59 | #255 (permalink) |
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | check shorting in nokia 1616 rh125 x gold chip-set.......... 1..remove the pf n7100 mark in (1)...if u want to check is pf is short remove it and check shoting...if it is shot then replace it... 2..remove coil l2503 mark in (2)...light driver transistor v2500 got +b through this coil ...if this transistor is short then remove this coil to check shorting cause by this transistor.... 3..at end remove d1000 xgold ic to check shoting is gone or not .... some usefull info about nokia 1616 rh125 & xgold d1000....... this is new handset launched by nokia with xgold chip-set ... d1000 is the main ic in the handset which control all the things in the handset like charging,sim,ringer,speaker,light,keypad,dispaly.. .etc... this ic got +b from battery and generates volt for display (vaux) and sim (vsim)...it also control the display and work as cpu... in simple words this ic is the combine form of power ic ,audio ic,charging ic,ui ic,and cpu.. there are some useful repair tricks about this handset which are on pic attached below... user who want to download the schematic here is the link... Deposit Files all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .... best regards, digitized |
The Following 11 Users Say Thank You to digitized For This Useful Post: |
