Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 11-07-2012, 23:46   #481 (permalink)
ren_mglab's Avatar
Member: 1501033
thanks sir i do what you said then i found out combo ic well heat...
thank you sir keep on helping
Old 11-29-2012, 20:03   #482 (permalink)
Member: 1806349
Hi bro my e71 is short plzzz provid solition with digram
Old 12-01-2012, 07:12   #483 (permalink)
Member: 334059
hello friend how are u
Old 12-18-2012, 19:08   #484 (permalink)
Member: 1806349
bro my nokia 2730 is short plzzz provid solution
Old 12-26-2012, 12:48   #485 (permalink)
Member: 1504955
Sonork: Pakistani
Originally Posted by jetset24 View Post
I have a issue ,6300 imei not showing *#06# = i want to input a new imei and it must work with the code (*#06#) to check imei , please can you give some guide line how can i overcome this issue...
also the other problem is if i dont use it for few minutes phone is auto off.
Battery is Fine, what can be the possible reason and how it can be resolved.
pls explain...
Thank you in advance
software flashing kay baad ime wash ho chukki hay is ka koi hal nahe hay mairay pass bhe aik 6300 hay us kay saath bhe same problem hay
Old 12-26-2012, 12:52   #486 (permalink)
Member: 1504955
Sonork: Pakistani
i got nokia 1600 i need power button shortcut ways it has power button problem can any one help me
Old 12-26-2012, 12:58   #487 (permalink)
Member: 1504955
Sonork: Pakistani
Talking Thanks
thanks brother on this post im very pleased
Old 12-27-2012, 08:48   #488 (permalink)
Member: 1851477
very goooooooooooooood
Old 02-03-2013, 15:44   #489 (permalink)
Member: 1851477
1616 1280 short sloution plz.............
Old 02-04-2013, 09:46   #490 (permalink)
Member: 1851480
Sonork: waiting ..<<<<>>>
nokia 6300 short solution .......... plz ........
Old 02-05-2013, 14:48   #491 (permalink)
mak1983's Avatar
Member: 1704666
Sonork: mak_9821014542@yahoo.co.i
bro try this...............................
File Type: jpg Nokia 6300_3500_3110c shourt solution ...jpg (65.9 KB, 10 views)
Old 02-10-2013, 10:40   #492 (permalink)
Member: 1878028
Sonork: niazali
Very nice
Originally Posted by digitized View Post
check shorting in 5310..
1..remove this coil mark in (1)...if u want to check is light ic is short,.....
2..remove this coil mark in (2)..if u want to check ringer ic is short because rf ic also got +b volt from battery....
3..remove this coil mark in (3)..if u want to check audio amplifier voltage maker ic n2101 is short because bluetooth ic also got +b volt from battery....
4..remove this rf ic mark in (4)..if u want to check the shorting is remove because rf ic got +b from batery. it can be check only by removing this ic
5..remove this ic mark in (5)..if u want to check the shorting is removed..this ic also got +b it can be check only by removing this ic .
6..also check the blue tooth ic because it also got +b from batery it can be check only by removing this ic
7..at end remove avilma and betty ic...
all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic ....
digitized
coolpanjabiguy@yahoo.com
dear nice sharing but iam new mobile repair dear plz tell me urdu languge plz iam waiting.
Old 02-11-2013, 07:56   #493 (permalink)
Member: 208059
Nokia asha 311 Display light and keypad light problem.all line ok but lights not work .
i check volt on lcd pad and near the lcd +ve point have 16volt just for when power on after that 0 volt and LED not work. give me solution for ths if you have good knowledge.
Old 02-13-2013, 10:38   #494 (permalink)
Member: 1418143
n8 short , nothing heat . what's can caused it ? I watched this Nokia N8 Full Short Done 100% Tested but I don't know what exactly i have to change , nothing explain in picture my post where I asked without answer
Old 03-05-2013, 10:44   #495 (permalink)
Member: 1893183
how to check nokia E5, Only vibrates nothing else. not even kepad light or sound.
The Following User Says Thank You to suniln For This Useful Post:
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.56399 seconds with 12 queries
