03-15-2009, 04:43 | #76 (permalink) | |
Freak Poster Join Date: Feb 2006 Location: Inside Boxes
Member: 228871 Status: Offline Thanks Meter: 43 | Quote:
Simply Rehot the Bluetooth Ic ur problem would be solved... | |
03-15-2009, 18:09 | #77 (permalink) | |
Insane Poster Join Date: Oct 2007 Location: kuwait
Member: 610630 Status: Offline Thanks Meter: 37 | Quote:
After ok give thankes. | |
03-20-2009, 09:19 | #78 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Research In Motion Age: 37
Member: 979016 Status: Offline Sonork: 1592061 Thanks Meter: 150 | I have 3110c full short and cmt err. already itry by using this solution but no result same........what can[B i do? plz help..........[/B] |
The Following User Says Thank You to rafiqcell For This Useful Post: |
03-26-2009, 09:22 | #80 (permalink) |
Freak Poster Join Date: Mar 2009 Location: india
Member: 995130 Status: Offline Sonork: SAMRAT Thanks Meter: 34 | have a n 70 its battery backup is only 16 hrs standby wats the problem is there any shorting NEW VERISION FLASH ONLY |
The Following User Says Thank You to panipat For This Useful Post: |
03-26-2009, 09:26 | #81 (permalink) |
Member: 995130 Status: Offline Sonork: SAMRAT Thanks Meter: 34 | camera is not working when i take a snap means this message is coming temporary over load when i open gallery means i takes 5 mintues or more time to open i am using memory card only 64mb i done format by pressing *3 call button and on/off switch format is completed and i done format mmc card also but 1 or 2 snaps again it get same problem so it better to do flash or any another problem is that and recently i done format after 3 days now it is working when i open blue tooth means again it is going and all are opening but songs in the mmc card is not playing when i open realplay it shows no data but i open file manager in that its showing the songs but unable to play why please please solve my problem as soon as possible bcoz its my fever ate pice and 1 more thing u r frm and is their espert in hyderabad to solve my prob did u have any i dea please solve my prob thanking you CHANGE BLUETOOH MODUL OK |
03-31-2009, 23:03 | #82 (permalink) |
Junior Member Join Date: Mar 2009
Member: 999360 Status: Offline Sonork: [email protected] Thanks Meter: 3 | N73 Nokia i wanna ask u compelet blue light not display no incoming not out going so plz tell me about this problem |
The Following 3 Users Say Thank You to Tasdeeqmuhammad For This Useful Post: |
05-03-2009, 07:46 | #87 (permalink) | |
Banned Join Date: Feb 2007
Member: 445578 Status: Offline Thanks Meter: 440 | Quote:
05-10-2009, 14:44 | #90 (permalink) |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | check shoting in nokia 1680 classic..... 1..remove this coil mark in (1)..if u want to check the light ic is short.... 2..remove this v.camdig ic n3301 mark in (2)..if u want to check the v.camdig maker ic ..this v.camdig maker ic got +b from batery....to make v,cam for camera..... 3..remove ringer ic mark in (3)..if u want to check shoting remove it and check if shoting is gone replace it because ringer ic also got +b volt from battery.... 4..remove the pf n7700 mark in (4)...if u want to check is pf is short remove it and check shoting...if it is shot then replace it... 5.. check vibrator it also got +b...remove it to check shoting.... 6..at end check the power ic and remove it to check shoting is there or not... all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .... wbr.. ..:Preet:.. |
The Following 6 Users Say Thank You to digitized For This Useful Post: |
