07-02-2009, 01:27 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Uk (Birmingham)
Member: 719944 Status: Offline Thanks Meter: 2,117 | engrs plz help in 6300 i got 6300 contact service problam...i did flash it with new ver as well..and rehot cpu and other ic,s but problam still same.. any body can help ,me in this regard thanxxxx in advance |
07-02-2009, 18:48 | #3 (permalink) |
Member: 719944 Status: Offline Thanks Meter: 2,117 | i did flash it again and logs here... ---------------------------------------- RPL backup thread finished, continuing... Backing up simlock... Simlock backup problem -> Phone not detected Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm217__07.21.mcusw (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 14400107BB450052B898C0A34405233AE86EC8D1 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 191EC665DFAAF68F rm217__07.21.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 3.25Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC220800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Flashbus Write baud set to 4.0Mbits Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00020000-0x0007FFFF, NOR EraseArea[0,CMT]: 0x00080000-0x000DFFFF, NOR EraseArea[0,CMT]: 0x00100000-0x001FFFFF, NOR EraseArea[0,CMT]: 0x00200000-0x0031FFFF, NOR EraseArea[0,CMT]: 0x00320000-0x0105FFFF, NOR EraseArea[0,CMT]: 0x01060000-0x01067FFF, NOR EraseArea[0,CMT]: 0x01068000-0x0107FFFF, NOR Waiting 320s for erasure finish... Erase taken 38.735s Writing all blocks... Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Writing CMT PMM_CONF Certificate... Writing CMT SBIF_CONF Certificate... Programming Status OK! All blocks written OK! Time taken 463.890s Restarting MCU... Processing rm217__07.21.mcusw (APE)... Processing rm217__07.21.ppm_i (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 14400107BB450052B898C0A34405233AE86EC8D1 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 191EC665DFAAF68F rm217__07.21.ppm_i, Type: Flash Image, Algo: BB5, BB5 ALGORITHM RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 3.25Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC220800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Flashbus Write baud set to 4.0Mbits Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 Started group flash erase EraseArea[0,CMT]: 0x01080000-0x015FFFFF, NOR Waiting 320s for erasure finish... Erase taken 11.578s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 144.156s Restarting MCU... Processing rm217__07.21.ppm_i (APE)... Processing rm217__07.21.image_i_white (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 14400107BB450052B898C0A34405233AE86EC8D1 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 191EC665DFAAF68F rm217__07.21.image_i_white, Type: Flash Image, Algo: BB5, BB5 ALGORITHM RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 3.25Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC220800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Flashbus Write baud set to 4.0Mbits Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 Started group flash erase EraseArea[0,CMT]: 0x01600000-0x01FDFFFF, NOR Waiting 320s for erasure finish... Erase taken 17.812s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 151.984s Restarting MCU... Processing rm217__07.21.image_i_white (APE)... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Factory defaults OK Reading info... Failed to read info -> Phone not detected Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! |
07-02-2009, 18:58 | #4 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: BANGLADESH
Member: 852543 Status: Offline Thanks Meter: 2,338 | Quote:
plz help me 6300 no network | illu | Nokia Hardware & Hardware Repair | 4 | 05-02-2010 08:18 |
Hi respectable Engeers plz help in ........ | chohansahib | iPhone 2 / iPhone 3G / iPhone 3GS | 17 | 03-31-2010 18:57 |
plz help nokia 6300 plz plz | qadriatta | Nokia Hardware & Hardware Repair | 5 | 12-20-2009 10:45 |
please help help help in 6300 | fessi | Nokia Base Band 5 ( BB-5 ) | 7 | 09-06-2009 11:59 |
experts plz help in 6300 | chohansahib | Nokia Hardware & Hardware Repair | 3 | 12-19-2008 23:49 |
