Old 10-01-2004, 14:21   #1 (permalink)
Registered User
Member: 23656
Erase can.Flash MCU&PPM can't
Hello...all..
Use Griffinbox ver2.0861
Nokia 6600 after flash with 6600-fullerase.fia. Can't flash back with MCUandPPM.
The messange show like this:
Initializing Phone...
Flash configuration:
9B040001007E25022540000201007E25...
Error[BDBDADAD]
Flash with 6600-fullerase.fia can.
Please Help me HOW to Fix this Problem.
Thanbks.
Old 10-01-2004, 16:47   #2 (permalink)
garmani's Avatar
Member: 43758
May be a HW problem with flash chip... or FIA files is to old...
Old 10-01-2004, 16:53   #3 (permalink)
Alkapone's Avatar
Member: 19265
Thanks Meter: 92
Skip bluetooth flashing, maybe will work.
Regards
Old 10-01-2004, 17:42   #4 (permalink)
Member: 1060
Thanks Meter: 10
try to replace D315 load for MCU, also D317 !
Old 10-03-2004, 07:49   #5 (permalink)
::Yasir::'s Avatar
Member: 47281
Thanks Meter: 17
is it possible to flash 6600 with griffin through bluetooth and skipping cable method??
Old 10-03-2004, 08:06   #6 (permalink)
pazeth™'s Avatar
Member: 74519
Thanks Meter: 79
when you erase may be make some mistake, make sure do not choice mcu in grffin, just ppm flash only if you wanna erase I think your is now seriously damage, change flash IC is solution
Old 10-03-2004, 13:45   #7 (permalink)
Registered User
Member: 23656
I try to change 3 flash inside already. But the same Problem.
Who have any way for repair it. PLease Give som idea.
Thankssss.
Old 10-03-2004, 16:57   #8 (permalink)
Alkapone's Avatar
Member: 19265
Thanks Meter: 92
Tryed to Skip BlueTooth flashing??? same problem hapends with 7650 nokia. Try to flash PPM only - if ok, than bluetooth failure, if not ok, flash IC, UEM.
Regards
Old 10-09-2004, 20:59   #9 (permalink)
Unggul's Avatar
Member: 71273
Thanks Meter: 14
your MAD phone faults.
Best Regards
Unggul
Old 10-10-2004, 08:09   #10 (permalink)
Member: 57061
Arrow
Pls Have The Solution For 6610 Ringer Not Wring
Old 10-10-2004, 08:57   #11 (permalink)
Bohosh's Avatar
Member: 14741
Thanks Meter: 119
Check the ringer,if it's ok, flash the phone and set factory to default
Old 10-12-2004, 10:40   #12 (permalink)
Member: 86182
BDBDADAD : MCU and PPM versions are not the same, Verify that you have the lastest FIA - files installted
Old 10-13-2004, 03:02   #13 (permalink)
Member: 67752
ya chang fia files good luck
Old 11-04-2004, 22:52   #14 (permalink)
almoudamer's Avatar
Member: 6572
Thanks Meter: 26
hi
@ willy and all
i have the same problem with "thlorkvannak"
if u need to flash 6600-fullerase.fia,it can erased ok
but,if u want to flash mcu and ppm it give this error with griffin
Error[BDBDADAD]
and this with tornado
1st Boot Ok, WD2, UPP: 0082
Fl0: 0x00000000-0x007FFFFF,0001267E,Amd 29BDS643HT
Fl1: 0x02000000-0x027FFFFF,0001267E,Amd 29BDS643HT
Fl2: 0x04000000-0x047FFFFF,0001267E,Amd 29BDS643HT
Fl3: 0x06000000-0x067FFFFF,0001267E,Amd 29BDS643HT
Algorithm: w2_amd.fia, w2_cbusb.fia
Algorithm Ok, MSID: 843A8DF304A7C19947ACDAE682
Decoded MSID: 3E4EBAF7-00C741A1-A8000000
Encoded FAID: BE1B7A4E-CCBE7E89-65EBAF3E
Cbus Boot Error: 9
Error Data1:
00000000: 00 96 84 3A 8D F3 04 A7 C1 99 47 AC DA E6 82 87 ...:......G.....
00000010: 26 02 26 10 01 04 01 00 7E 26 02 26 10 01 06 01 &.&.....~&.&....
00000020: 00 7E 26 02 26 10 01 FF FF FF FF FF FF FF FF FF .~&.&...........
00000030: FF FF FF FF FF FF FF 83 00 00 00 00 00 00 00 00 ................
Error Data2:
00000000: A3 72 72 7E 26 02 26 10 01 02 01 00 7E 26 02 26 .rr~&.&.....~&.&
00000010: 10 01 04 01 00 7E 26 02 26 10 01 06 01 00 7E 26 .....~&.&.....~&
00000020: 02 26 10 01 FF FF FF FF FF FF FF FF FF FF FF FF .&..............
00000030: FF FF FF FF 83 C3 72 99 9A 30 96 62 D8 BE F7 64 ......r..0.b...d
Before taking screenshot, expand this window !
Process Failed, Repowering Mobile
i already changed the 4 flash chip 2 times ,first i used AMD and then tried ST type
Upp ,and the glued Uem is also changed
just to let u know ,i have also 3650 with same problem
and the 2 phone are water damaged
so,i think there is a track leckage
finally best regards
can flash e1100t VINOD399 NSPRO 0 03-29-2010 11:30
N73 can flash but can't on lokkinho Nokia Hardware & Hardware Repair 2 05-16-2008 17:15
6630 imei 1234..... after erase and flash - rpl & imei backup can't solve the problem BouRRi_GSM Nokia Base Band 5 ( BB-5 ) 7 05-14-2007 13:55
6260 can flash after doing erase FLASH. myrocky WD2 & APE (Symbian Phones) 7 05-14-2005 09:15
8210- can flash but can't sw On andrews Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 12-30-2002 03:57
Page generated in 0.23003 seconds with 9 queries
