02-21-2007, 07:43 | #1 (permalink) |
No Life Poster Join Date: Mar 2003 Location: India Age: 73
Member: 23587 Status: Offline Thanks Meter: 63 | Everybody can contribute here in this thread I have been hearing from lots of technicians that a simple resistance TEST between the 2 Battery Terminal Contact Points on the PCB (without the Battery) in Forward and Reverse directions helps know whether the problem is in Phone's Hardware or Software. Let us decide here first what we are going to say FORWARD RESISTANCE and what we are going to call REVERSE RESISTANCE : FORWARD RESISTANCE :Connect the Black Probe of the Digital multimeter to the +ve pin of the Battery Connector and to the -ve pin of the Battery Connector, connect the Red Probe of the DIGITAL METER. REVERSE RESISTANCE : Now Connect the Red Probe of the Digital multimeter to the +ve pin of the Battery Connector and to the -ve pin of the Battery Connector, connect the Black Probe of the DIGITAL METER. or in brief : FORWARD= +VE(B) BLACK(M) & -VE(B) RED(M) REVERSE = +VE(B) RED(M) & -VE(B) BLACK(M) Fellow forum members, please post readings that you get in different Nokia models here. Don't forget to mention whether it is from a working phone or a non-working (DEAD or not switching ON) phone. If the phone is switching ON but is having a different problem, please mention the problem. To maintain uniformity, please post as per example below : NOKIA 3310 OK FORWARD RESISTANCE ____OHMS REVERSE RESISTANCE ____ OHMS NOKIA 3315 NOT SWITCHING ON FORWARD RESISTANCE ____OHMS REVERSE RESISTANCE ____ OHMS Last edited by 1amigo; 02-22-2007 at 13:10. |
02-22-2007, 12:45 | #3 (permalink) |
Member: 23587 Status: Offline Thanks Meter: 63 | Shall we proceed? NOKIA 3310 OK FORWARD 380 OHMS REVERSE NO READING ANALYSING FORWARD RESISTANCE READING : Now here, I would like to say that the FORWARD READING in most OK phones will be between 300 to 700 ohms. However, this reading is mostly OK only. (1) If it is lower than indicated in this range (lower than 300 ohms), there is a likeliness of a direct shorting in the circuit like a PA or any other component which is connected directly to the +ve Battery Line or even a shorting between the + & - tracks on the pcb anywhere because of bad soldering or solder getting spread or dropped inadvertantly. (2) If the reading is ok - no specific inference can be drawn. However, it also somewhat indicates the possibility of a SOFTWARE PROBLEM. (3) If the reading is more than 700 ohms, most likely causes can be either a broken +ve line track or an open coil on the +ve line.[/ ANALYSING REVERSE RESISTANCE READING : (1) If this Reverse Resistance shows any ohms, it means that there is a leaky part in the hardware and so it is definitely a HARDWARE FAULT. If after rectifying this fault, the phone can still be not switched ON, you may need to rectify a possible SOFTWARE PROBLEM BY FLASHING IT ETC. (2) The Reading 1 in the digital multimeter means no reading or infinite resistance. Infinite means very high resistance. Ideally this Infinite reading in REVERSE RESISTANCE test is ok. SO this again increases the possibilty of a SOFTWARE PROBLEM which was also indicated above in FORWARD RESISTANCE TEST. (3) For Infinite reading in REVERSE RESISTANCE test, also you must check for an open track in the circuit. Correcting n open track should not make any difference in this reading. (4) If the reading is within specified range or less than 300 or more than 700 ohms, there is also a possibility of a open or short in the secondary supply lines like Vbb,Vcore,Vcxo etc. . Comments please from everyone knowing about it or wanting to know ! Last edited by 1amigo; 02-22-2007 at 13:06. |
02-22-2007, 13:23 | #4 (permalink) |
Member: 23587 Status: Offline Thanks Meter: 63 | Some More Ok Readings FORWARD READING in most OK phones will be between 300 to 700 ohms. NOKIA 3120 FORWARD 330 REVERSE NIL SE W550i FORWARD 440 REVERSE NIL SAMSUNG E700 FORWARD 520 REVERSE NIL |
02-27-2007, 14:33 | #5 (permalink) | |
Member: 23587 Status: Offline Thanks Meter: 63 | Quote:
I think you and me are the only 2 persons interested to discuss or post in this topic . So, now it is your turn to post . POST PLEASE ! Let us do the BEST we can ! | |
02-28-2007, 13:06 | #7 (permalink) | |
Well, as you have understood what i wrote in my earlier post, just get any mobile (working or not-working) and measure the resistance between the 2 battery terminals as described - FORWARD & REVERSE. Write it down and post as in the example given by me here. It can be as below : MAKE & MODEL NO. : ___________ STATUS : SWITCHING ON OK / NOT SWITCHING ON (DEAD) FORWARD RESISTANCE : __________ REVERSE RESISTANCE : __________ THAT'S ALL, MY FRIEND. TRY ONCE PLEASE. | |
02-28-2007, 18:27 | #9 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 205738 Status: Offline Thanks Meter: 129 | As i test at batt terminal is the status of handset i.e. its short , open , leakage or close(ok) circuit........ you will get reading over 1 Mega ohm...i.e.of ok handset...in reverse wbr... |
03-01-2007, 05:35 | #11 (permalink) | |
Member: 23587 Status: Offline Thanks Meter: 63 | Thanks MumbaiGsm Quote:
Please post some readings. You also know how to make use of the readings, so please also post your comments on the readings obtained by you. Best regards, | |
03-02-2007, 02:11 | #12 (permalink) |
No Life Poster Join Date: Mar 2006 Location: pakistan Age: 71
Member: 241039 Status: Offline Thanks Meter: 4,170 | dear lamigo,, ..:MumbaiGsm:.. is right there are only three option 1- short ( as short ) 2- open ( o, ohm) 3- normal (over 1 mega ohm) one thing more the impendence of every moble is different ,after use and after hardware it has changed , u can test the same two mobile , check difference ,even the new two set , regards rashid |
03-02-2007, 05:53 | #13 (permalink) | |
As you may have observed in earlier posts, i have made a point to mention that all forward resistance readings falling in the 300-700 ohms range are more or less acceptable as OK readings. So we shouldn't be much worried if the forward readings from 2 handsets of the same model differ but still fall within this range. I understand this is what you are trying to say in the 2nd para of your post, right? You are very right about it. I endorse your valuable opinion. My point was to guide Beginners to perform this TEST first and then judging from the results of this test, go to appropriate section, Hardware or Software for further investigation. I think you will agree to it. | |
OFFTOPIC posts or posted in wrong thread - all moved in this thread from today 26feb | Expertcell | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-26-2010 03:54 |
Samsung A707 can be lock in this thread? | kornmation | QUALCOMM Models (3G) | 0 | 10-16-2007 17:17 |
