10-27-2007, 08:51 | #1 (permalink) |
Insane Poster Join Date: May 2007
Member: 508595 Status: Offline Thanks Meter: 14 | 3310 flash ok, ui setting default ok but phone is stii dead psl. hlp regards tarik |
10-27-2007, 09:05 | #2 (permalink) |
Junior Member Join Date: Jun 2007 Location: Pakistan
Member: 522149 Status: Offline Thanks Meter: 1 | dear cheack 1st on/off then cheack this imege best regards www.******************.net www.******.***********.com |
10-31-2007, 11:04 | #7 (permalink) |
No Life Poster Join Date: Jul 2006 Location: IBADAN, OYO STATE, NIGERIA
Member: 319112 Status: Offline Thanks Meter: 164 | Try And Check The Positive Ways On The Panel. Check Especially The Link Between The Yellow Capacitors And The Positive Pad On The Board.ALSO CHANGE IN A NEW UI IC WITH TWENTY LEGS. IT CONTROLS LEDS, DISPLAY,RINGING AND VIBRATION. Last edited by ABUU YUUNUS; 10-31-2007 at 11:10. |
..::1202 flashing and ui setting ok but no power::.. | HUM | Nokia Hardware & Hardware Repair | 42 | 04-14-2013 05:55 |
..::nokia 1200-1208 Flashing And Ui Settings Ok But No Power Solution::.. | HUM | Nokia Hardware & Hardware Repair | 56 | 11-23-2011 09:11 |
1200 flash ok ui setting ok normal mode ok but not no by power switch switch volt ok | Punit Kumar | Nokia Digital Core Technology 4 ( DCT-4 ) | 7 | 02-25-2010 12:58 |
n90 flash ok ui setting ok but no power on | raknahs | Nokia Hardware & Hardware Repair | 1 | 04-07-2008 17:40 |
Flashing N95 with jaf ...APE error at Step 3..but phone is not dead! | Hiro1981 | Nokia Base Band 5 ( BB-5 ) | 0 | 09-17-2007 18:30 |
