08-19-2007, 11:54 | #1 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 453587 Status: Offline Thanks Meter: 0 | First tes for dead phones Can someone please describe what are the steps to make the correct tests, should I use the avometer? Please help, this could be a very good thread! |
08-19-2007, 12:07 | #2 (permalink) |
No Life Poster Join Date: Aug 2006
Member: 337450 Status: Offline Thanks Meter: 718 | First ask the customer first what happen to the phone, but surely some of them may lie...... Very first step is by checking the battery voltage if has proper voltage to execute.... Next test the terminal if good, or use VOM for short testing. If not Short proceed to software, test if goes to local mode, if not hardware problem.... |
08-19-2007, 12:11 | #3 (permalink) | |
Member: 453587 Status: Offline Thanks Meter: 0 | Quote:
Very good answear, of course we need more But please can you describe how to check battery voltage and the terminal...etc? I need this information, because I am newbe Thanks for the guide!!!!!!!!!!!!!! | |
08-19-2007, 12:19 | #4 (permalink) |
Member: 337450 Status: Offline Thanks Meter: 718 | Most batteries are 3.7v, if you test using VOM in DCV10 probe it must be in 3.2V a test for a good battery..... If not battery is bad, or you can do it by shocking it via 9 volts to keep it active....Terminal testing is by putting its probe in positive and Negative pins, positive and negative may react at VOM via x1 or x10 resistance. try to reverse it, if still react unit is short, you can also use your digital power supply.... |
08-19-2007, 12:27 | #5 (permalink) | |
Thanks! So if I put the ( - ) from the avometer on the ( - ) of the phone and the (+ ) from avometer to (+) should it give me 99,9999999999 and the oppisit 00,000000000001 Is this write or wrong for a good working phone without short? | |
08-19-2007, 14:46 | #6 (permalink) |
No Life Poster Join Date: Jun 2002 Location: Iran Age: 47
Member: 12724 Status: Offline Thanks Meter: 30 | First test is power consuming test for me. connect phone to your power suplly and press phone's power on key. It will be half of your way repairing phone! |
first solution for dead 5800 by zulee unlocker | nimanima | Nokia Base Band 5 ( BB-5 ) | 1 | 06-09-2009 05:26 |
C 28 v. 61 solution for dead phone | Mtelko | x1x to x45/x50 | 4 | 04-07-2001 20:29 |
C25 v61: Are there any solutions for dead phones? | chris_ua | x1x to x45/x50 | 0 | 02-13-2001 20:02 |
C25 v61: A solution for dead phones... maybe. | chris_ua | x1x to x45/x50 | 5 | 01-29-2001 07:31 |
Do have solution for DEAD phone? | Charlie | Old Ericsson Phones & Sony Phones | 6 | 04-11-2000 02:14 |
