fix band nokia 800-1900mhz hello all need a solution for fix band nokia 800-1900mhs is possible :) |
hi there are some solutions available. But your mode of posting a question is not proper. You vent even mentioned the model of Nokia phones. For which model you need to convert band?? SO pl post ur question with full details. ANd before that you should have used the SEARCH function. Regards |
hi i have nokia 3390 after unlcok not network it possible to fix band 800-1900mhz where converter |
hi all to possible to converter nokia 3390 to 3310 please help 8390 to, 8310 5130 to 5110 8290 to 8210 :confused: :confused: |
have you any programs to tune the phone with? Try tuneing the phone, if you can... |
@Engineer Wat type of Tunning ? hehe.. why you just jumping into the pond when you dont know how to swim. Collective modification on both the sides are necessary to convert such 1900mhz phones. I want to say: hardware mods as well as software manipulation needs to be done. Some very useful pictorial guides available at all pinoy forum. YOu search n you gonna get those files. Best luck. |
first change the PA and 2 little transistor near the crystal dont ask picture you have to compare with 3350 |
@engineer thats impossible while its not tunning matter its about hardware changes @sayhu please you look at the board deign to see that the pf and the if filters is not same as use for gsm 900 and 1800 mhz the modification available only for 3390 to 3350 or 3330 br. |
it is possible, need to do some modifications on phones HARDWARE first. |
is it possible 8390 to 8310 |
3390 to 3310 yes i did not try anything else. software and hardware modifications. |
do u have pics? please explain how to change 3390 to 3310. |
