Old 04-08-2004, 20:06   #1 (permalink)
abdoulaye's Avatar
Location: senegal (dakar)mali/guinee/mauritanie[KANDJI ET FRERES]
Member: 41375
Thanks Meter: 7
fix band nokia 800-1900mhz
hello all
need a solution for fix band nokia 800-1900mhs is possible
Old 04-08-2004, 20:22   #2 (permalink)
i_seeque's Avatar
Member: 15238
Thanks Meter: 119
hi
there are some solutions available. But your mode of posting a question is not proper. You vent even mentioned the model of Nokia phones. For which model you need to convert band?? SO pl post ur question with full details. ANd before that you should have used the SEARCH function. Regards
Old 04-09-2004, 14:33   #3 (permalink)
abdoulaye's Avatar
Member: 41375
Thanks Meter: 7
hi
i have nokia 3390 after unlcok not network it possible to fix band 800-1900mhz where converter
Old 04-09-2004, 14:43   #4 (permalink)
abdoulaye's Avatar
Member: 41375
Thanks Meter: 7
hi all
to possible to converter nokia 3390 to 3310 please help
8390 to, 8310
5130 to 5110
8290 to 8210
Old 04-10-2004, 16:22   #5 (permalink)
Member: 44658
have you any programs to tune the phone with?
Try tuneing the phone, if you can...
Old 04-12-2004, 10:42   #6 (permalink)
i_seeque's Avatar
Member: 15238
Thanks Meter: 119
@Engineer
Wat type of Tunning ? hehe.. why you just jumping into the pond when you dont know how to swim.
Collective modification on both the sides are necessary to convert such 1900mhz phones. I want to say: hardware mods as well as software manipulation needs to be done. Some very useful pictorial guides available at all pinoy forum. YOu search n you gonna get those files.
Best luck.
Old 04-13-2004, 09:20   #7 (permalink)
sayhu's Avatar
Member: 9355
Thanks Meter: 113
first change the PA and 2 little transistor near the crystal dont ask picture you have to compare with 3350
Old 04-13-2004, 20:07   #8 (permalink)
Member: 7062
Thanks Meter: 121
@engineer
thats impossible while its not tunning matter its about hardware changes
@sayhu
please you look at the board deign to see that the pf and the if filters is not same as use for gsm 900 and 1800 mhz
the modification available only for 3390 to 3350 or 3330
br.
Old 04-14-2004, 16:27   #9 (permalink)
mansi's Avatar
Member: 8664
Sonork: 100.1573507
Thanks Meter: 56
it is possible, need to do some modifications on phones HARDWARE first.
Old 08-28-2004, 16:21   #10 (permalink)
Nizamo's Avatar
Member: 48505
Sonork: 100.102180
Thanks Meter: 33
is it possible 8390 to 8310
Old 09-01-2004, 03:11   #11 (permalink)
mansi's Avatar
Member: 8664
Sonork: 100.1573507
Thanks Meter: 56
Originally Posted by abdoulaye
hi all
8390 to, 8310
5130 to 5110
8290 to 8210
3390 to 3310 yes i did not try anything else.
software and hardware modifications.
Old 12-14-2004, 21:18   #12 (permalink)
gsmuy's Avatar
Member: 65216
Thanks Meter: 23
do u have pics? please explain how to change 3390 to 3310.
Old 12-21-2004, 06:17   #13 (permalink)
i_seeque's Avatar
Member: 15238
Thanks Meter: 119
visit forum ed2k.com.ph - it is an age old solution now! USE search feature of this great forum.
is there any idia to change band to 800/1900 yarra Infinity-Box 2 07-29-2009 09:20
possibility of converting a single band to dual band Nokia 3300 Suleiman Abdul Nokia Hardware & Hardware Repair 1 04-06-2005 14:56
fix band nokia 800-1900mhz abdoulaye Griffin 12 09-04-2004 13:56
fix band a56 t50 abdoulaye E-Gold Based Phones 1 04-09-2004 19:43
how to make T720 biband 800/1900mhz? infogsm Motorola P2k 1 12-22-2003 20:35
Page generated in 0.46206 seconds with 8 queries
