Old 05-03-2004, 07:47   #1 (permalink)
Member: 61249
Lightbulb FPS4 to DCT4
Hello Everybody,,,,
I have one FPS4, TDF 4 & FLA 7.
All are activated and are using for flashing wintesla phones.
My question is that, can i use these boxes to flash DCT4 phones.
Is there any special connection arrangement to make flashing for DCT4 phones.
Or
is there any other way to flash dct4 phones by using FPS4
Thanx in Advance
Best Regards
Techman
Old 05-03-2004, 08:39   #2 (permalink)
vule's Avatar
Member: 10854
Sonork: 1578988
Thanks Meter: 3
As long as i know, You can't use fps4 for dct4 flashing...
But fps8 can flash both dct3 & dct4 phones, you only need to install wintesla fps8 support dll's
Vule
Old 05-03-2004, 22:41   #3 (permalink)
Member: 44658
FPS-8 has there own inbuild memory cards.
6600 phones requires a minimum of 64MB to flash (standard is 32MB)
Also to flash a 3300 phone, you need a usb connection also, plugs into usb port, and other end goes into handsfree port...
Other than that, FPS-8 can flash all DCT4 phones
Old 05-07-2004, 14:11   #4 (permalink)
Member: 477
Originally Posted by techman
Hello Everybody,,,,
Or is there any other way to flash dct4 phones by using FPS4
Thanx in Advance
Best Regards
Techman
No, you cannot use the FPS-4 set for servicing DCT4 models.
Old 05-07-2004, 14:13   #5 (permalink)
Member: 477
Vule
and install the ACS-10 power supply module into the FPS-8 for servicing DCT3 models.
Old 05-07-2004, 14:16   #6 (permalink)
Member: 477
24Mb SRAM in the FPS-8 will work to flash the 6600, only if the MCU file is not bigger then 24Mb, otherwise you have to install an extra SRAM module of 8Mb. 32Mb of SRAM in the FPS-8 will work fine for the 6600, together with the standard 16Mb Flash Mem.
Old 05-07-2004, 14:18   #7 (permalink)
Member: 2100
Thanks Meter: 40
if someone thinks he has not enough memory in fps-8, contact me ;-)
Old 05-07-2004, 14:21   #8 (permalink)
Member: 477
Yes, this is really true and you need it anyway in the future, these extra SRAM modules :-)
How to activate my boX to dct4+ phones. mayreddy Universalbox 8 09-06-2009 17:18
exchange unlock sharp unprotect to soft generate codes to dct4-5 valti Exchange Section 2 04-08-2003 19:09
change imei to dct4 firas_af Nokia Multimedia 7 03-19-2003 15:47
HEX for dongle to DCT4 calculator need... otinger Wanted Products 1 03-12-2003 21:22
Page generated in 0.30953 seconds with 8 queries
