07-10-2004, 04:22 | #1 (permalink) |
No Life Poster Join Date: Dec 2001 Location: In front of my computer
Member: 7741 Status: Offline Thanks Meter: 111 | 3315 detects 4.01V v using ACP-7X (slow charger) ACP-7X (SLOW TRAVEL CHARGER ORIGINAL) and checked at the + - battery pins without battery and i fouind out that the multimeter detects 4.01V from the phone (normally is 3.61V - 3.66V). And i use a ACP-8E (FAST TRAVEL CAHRGER ORIGINAL) and the multimeter detects 0.02V (Normally is around 3.67V - 3.70V). So i tried to change the CHAPS. And the problem still the same. After that, I changed the CCONT. The problem still the same, And then i change the PA's too, but the problem sitll the same, please assist!!! There is no broken links between the tracks of the normal track broken issue ( near the CHAPS) and i already check the fuse too , still the same. Please assist!!!! Thanks in advance |
07-10-2004, 10:48 | #2 (permalink) |
No Life Poster Join Date: May 2004 Location: gsm-land Age: 45
Member: 67419 Status: Offline Thanks Meter: 237 | in most cases there are 2 the problems that your phone works too slow. 1-flash ic (if it is water damage you can clean it) 2-32.768 khz time clock(you must listen the ring if it is too slow you must change it) you have to try the second first becouse is too easy . after you must flash the phone br |
07-11-2004, 18:09 | #3 (permalink) |
Member: 7741 Status: Offline Thanks Meter: 111 | i already full flash the phone cos it's a water damaged phone, which the phone sometimes turn on and sometimes won't. i suspect the flash ic which makes this sometimes turn on sometimes don't prob. but i don't think the 32.768khz prob cos the ring tones runs perfect (no slow at all) no signal up and down too. But i don't think the flash ic will cos the voltage abnormal while charging!!! Right? Thanks for your kind help guys. But I still needs more answers from this problem of the abnormal charging valtage. |
07-11-2004, 18:26 | #5 (permalink) |
Member: 7741 Status: Offline Thanks Meter: 111 | read my post clearly. SLOW TRAVEL CHARGER for nokia is :- ACP-7X (SLOW TRAVEL CHARGER ORIGINAL) FAST TRAVEL CHARGER for nokia is :- ACP-8E (FAST TRAVEL CAHRGER ORIGINAL) |
Nokia 3315 C,4,7 & * Not Working.... | amit123 | Nokia Hardware & Hardware Repair | 3 | 05-01-2010 04:13 |
(Ask) Fail to detect RM-146 5300 using USB cable, why? | gatot_susatijo | Nokia Base Band 5 ( BB-5 ) | 3 | 05-26-2008 21:14 |
cannot detect com port when using SECBOX | preshaust | Cruiser Suite | 10 | 09-11-2007 20:04 |
3315 shows Tx low while using Banana Tool | ..:MumbaiGsm:.. | Nokia Hardware & Hardware Repair | 3 | 12-27-2005 12:45 |
View ver. 10.4. Write "Use rechargeable batt. to unlock" | Sedy | Alcatel & TCL Old Models | 0 | 07-03-2000 08:23 |
