12-31-2010, 06:49 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: india Age: 39
Member: 650853 Status: Offline Thanks Meter: 118 | Get ALL NOKIA Problems I Solved In Only 1 hours |
The Following 3 Users Say Thank You to micro_hsr For This Useful Post: |
12-31-2010, 08:13 | #3 (permalink) |
No Life Poster Join Date: Jun 2008
Member: 792254 Status: Offline Sonork: al_jadeed Thanks Meter: 171 | i find 2 print and charging ok but when remove charger .set still. show charging.plz help |
The Following User Says Thank You to asif-rashid For This Useful Post: |
12-31-2010, 11:08 | #4 (permalink) |
Junior Member Join Date: Nov 2007
Member: 639546 Status: Offline Thanks Meter: 4 | Nokia N81 Flex Problem Please post the Flex camera Tracks because my Flex is little broken. And the new flex is not available, below i have given the broken part due to which my camera shows feature not supported N earpiece Don't work, do your solution will work in my case. Pls. reply. |
The Following 2 Users Say Thank You to Shoaib1989 For This Useful Post: |
12-31-2010, 21:20 | #6 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Nigeria
Member: 620382 Status: Offline Thanks Meter: 18 | Pls, I have a nokia 1600. When I insert battery, it shows charging. How can I solve the problem? |
The Following User Says Thank You to tundealade For This Useful Post: |
12-31-2010, 21:38 | #7 (permalink) |
Freak Poster Join Date: Dec 2007 Location: karachi
Member: 643460 Status: Offline Thanks Meter: 93 | 5130 power botton problem i have change keypad ic even apply jumper after ******* into the body power button not working auto on off....... |
The Following User Says Thank You to khurram_player For This Useful Post: |
12-31-2010, 21:40 | #8 (permalink) |
Member: 643460 Status: Offline Thanks Meter: 93 | 7310 have display prolem white screen chage lcd all print ok pice condition is ok still white screen even also reinstall software |
01-01-2011, 17:28 | #12 (permalink) |
Junior Member Join Date: May 2007
Member: 505433 Status: Offline Thanks Meter: 1 | I am facing a problem with Nokia E65. Symtoms: It hangs and restarts if media is played or the mobile is put to use for continuous 10-15 minutes. Restart occurs with a beep. The phone restart after 15 minutes of charging and restarts after 20 minutes of normal usage. However, when idle, it does not hang or restart automatically until 3 to 4 hours. Steps Taken: I have changed the battery, re-flashed phone several times, both with box as well as USb cable with versions 1 to 4 (v4 being the latest firmware version) and formatted file system, restarted via restart codes etc but the end result has been the same. --> Kindly tell me what might be the problem. Do i need to replace any component and if yes then which one? A diagram will help. If there is some other solution then please also share. Thanks |
The Following User Says Thank You to timematcher For This Useful Post: |
01-02-2011, 11:51 | #13 (permalink) |
Junior Member Join Date: Apr 2007
Member: 489744 Status: Offline Thanks Meter: 6 | 3600 s nokia auto charging problems when changed hedset connector this roblems come plzzzzzzzzzzzzzzzzzzzzzzzz solutions fast |
The Following User Says Thank You to bikramrai For This Useful Post: |
01-07-2011, 10:42 | #15 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1334685 Status: Offline Sonork: [email protected] Thanks Meter: 1 | nokia n82 i brought an dead nokia n82 when i charge the battry & press on button no response other than vibrator giving response.. help me to turobleshoot it.. |
The Following User Says Thank You to coolkanu For This Useful Post: |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
