09-08-2010, 05:43 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Afrique du sud Age: 42
Member: 430612 Status: Offline Thanks Meter: 301 | Good resistor and bad resistor |
The Following User Says Thank You to luyanda For This Useful Post: |
09-10-2010, 00:47 | #6 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Paradise on Earth
Member: 385828 Status: Offline Sonork: 100.1612815 Thanks Meter: 73 | u can check the value of resistor with multimeter before measuring the value u must know the calculated value ( based on color codes, numbers and in cell phone u use component descriptions) . when u measure the value with multimeter its called measured value . now u have check the difference between with calculated value & measured value depending upon tolerance ( + or - 2%, 5% or 20%) depending upon resistor. e.q if u 100k resistor its value could be 95k or 105k ( +/- 5%) if under measuring value it give value more or less with in tolerance ( e.g 100k shows 120k value or 100k shows 80k then u have replace it. i hope u understand. |
The Following 4 Users Say Thank You to sheikh1777 For This Useful Post: |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
