Old 02-20-2008, 20:09   #1 (permalink)
Member: 637625
Thanks Meter: 39
hello boys help me###
nokia 1600 car kit problem
Old 02-21-2008, 03:58   #2 (permalink)
agent_lia's Avatar
Member: 291404
Thanks Meter: 58
sir try to clean the charging pin.......hope it can help
Old 02-21-2008, 06:21   #3 (permalink)
iqballk's Avatar
Member: 13932
Sonork: 100.1609876
Thanks Meter: 410
just change this for HF problems..
regards..
Old 02-21-2008, 08:58   #4 (permalink)
ansari123's Avatar
Member: 292789
Thanks Meter: 636
dear make this jumer see on image
then reply
Old 02-21-2008, 09:25   #5 (permalink)
Member: 390858
Thanks Meter: 29
then reply
did you try this solution and it worked fine.
Old 02-21-2008, 09:42   #6 (permalink)
Member: 637625
Thanks Meter: 39
beautiful solutions
its not ok create this jumper
Old 02-21-2008, 09:53   #7 (permalink)
Member: 318849
change connector charging and jumper above by mr.ansari. else,remove c2013 and replace it with jumper.but after you do this, the handsfree can't be used again.post the result
Old 02-21-2008, 10:01   #8 (permalink)
ansari123's Avatar
Member: 292789
Thanks Meter: 636
YES MY DERA I TESTED THIS SOLUTION MANY TIME
CHECK THIN REPLY ME
THANK,s FOR REPLY
..:::SAQIB ANSARI::..
Old 02-21-2008, 10:04   #9 (permalink)
ansari123's Avatar
Member: 292789
Thanks Meter: 636
YES WHEN U MAKE JUMPER THEN NOT WORK HANDFREE
BUT IF NOT WANT TO USE HANDFREE THEN MAKE THIS JUMER ITS WORK FOR WITHOUT HAND FREE USER
Old 02-21-2008, 10:30   #10 (permalink)
Member: 637625
Thanks Meter: 39
not ok
this parfect solution
Old 04-23-2008, 19:14   #11 (permalink)
Member: 66354
Thanks Meter: 15
then reply
yea it's workfine 100/100 tnkx
hello boys lilan sahoo Nokia Hardware & Hardware Repair 4 03-05-2009 08:24
hello boys please help lilan sahoo Nokia Hardware & Hardware Repair 2 01-08-2009 08:50
hello boys complate solution for 6270 white display lilan sahoo Nokia Hardware & Hardware Repair 11 08-13-2008 20:07
hello boys help me### lilan sahoo Nokia Hardware & Hardware Repair 4 03-21-2008 14:53
Hello pls help me My motorola Sp lock help me varma raj Motorola ODM 1 06-19-2003 22:39
Page generated in 0.24286 seconds with 10 queries
