Old 03-31-2008, 09:52   #1 (permalink)
kailash_gm's Avatar
Member: 101117
Thanks Meter: 466
help for 3230
hi all
i want urgent hep for 3230 set that have charging problem
as i put charger set show charging after 2 hours it says battry full
as i remove charger show battry low
any soln
plz its urgent
Old 03-31-2008, 10:12   #2 (permalink)
Member: 610630
Thanks Meter: 37
try to change uem................post result
Old 03-31-2008, 11:47   #3 (permalink)
jimm07ct's Avatar
Member: 426688
Sonork: 100.1596204
Thanks Meter: 524
Originally Posted by kailash_gm View Post
hi all
any soln
plz its urgent
bro,
check voltage on the battery conector,
if out put 3.5 v
then check set short or not?
if voltage lower then 3.5v then change charging ic
Old 04-02-2008, 19:28   #4 (permalink)
kailash_gm's Avatar
Member: 101117
Thanks Meter: 466
thanx for reply there was no shorting
but problem solved by just writing pm & file system format with jaf
Old 05-29-2008, 19:32   #5 (permalink)
zahidnawaz's Avatar
Member: 616556
Thanks Meter: 112
yes it work fine
i recover two pieces of 3230 now
Old 06-16-2008, 07:27   #6 (permalink)
sujan1050's Avatar
Member: 449518
Thanks Meter: 585
i need help for 3230 same key not work chronic Nokia Hardware & Hardware Repair 7 02-21-2010 12:46
Help for Nokia 3230 AnarchyWW Nokia Base Band 5 ( BB-5 ) 0 03-27-2007 20:53
Grifin Teem! Please help me with for 3230 problem GSM-BARAN MT-BOX 0 08-03-2006 08:00
help for 3230 ParsX UFS2 + UFS3-Tornadoflasher 7 05-18-2006 19:19
please help for 3230 jignesh_1000 Nokia Hardware & Hardware Repair 2 08-19-2005 08:27
Page generated in 0.23987 seconds with 9 queries
