06-13-2003, 14:05 | #1 (permalink) |
Crazy Poster Join Date: Oct 2002 Location: RP
Member: 17093 Status: Offline Thanks Meter: 0 | help 3310 ccont to hot |
06-13-2003, 15:08 | #5 (permalink) |
Member: 17093 Status: Offline Thanks Meter: 0 | i remove the hagar cobba and charging ic and i put supply to the phone ccont still hot. then i put back all ic then still the same. power consumtion reach up to .6 Amp. Sometimes ccont is in normal temperature but when i run wintesla to get rssi reading then it goes hot again power consumption goes high to .6 amp. This phone has no network to rssi reading -148. |
06-14-2003, 00:58 | #8 (permalink) |
Member: 17093 Status: Offline Thanks Meter: 0 | PA is good and try tor remove ccont still the same it is ok. But sometimes temperatures is ok only when i used wintesla to get rssi then it goes hot again. Most of the the ccont is hot |
06-14-2003, 17:18 | #10 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Never Land
Member: 7277 Status: Offline Sonork: 100.42158 Thanks Meter: 68 | check the line of continuity of vbat...maybe there are shorted components that's why the CCONT's very hot...if components are ok then maybe CPU is the main reason of your problem... |
8210 & 3310 ccont ... | VEX-CELL | Nokia Hardware & Hardware Repair | 2 | 11-01-2006 12:38 |
i need help in 3310 Ccont always worm with power on | Bido_Elgen | Nokia Hardware & Hardware Repair | 4 | 11-29-2004 09:19 |
3310 ccont hot | blackneck6666 | Nokia Hardware & Hardware Repair | 6 | 09-12-2003 21:43 |
8210 need rehot CCONT to power ON | Hary | Nokia Hardware & Hardware Repair | 2 | 12-02-2002 01:54 |
3310 ccont extra heat | .::AkhavanGSM::. | Nokia Hardware & Hardware Repair | 11 | 10-28-2002 07:51 |
