10-28-2010, 00:02 | #1 (permalink) |
Freak Poster Join Date: Aug 2008
Member: 828494 Status: Offline Sonork: kruger selection Thanks Meter: 18 | help 5130 n 2700c show nokia then turn white display and off |
The Following 2 Users Say Thank You to tol4ray For This Useful Post: |
10-28-2010, 06:41 | #3 (permalink) |
Banned Join Date: Jul 2010 Location: Bangladesh
Member: 1349829 Status: Offline Thanks Meter: 41 | hi to all gsm friend, i have problem fixing 5130 & 2700c phone even after flashing with latest files, still show nokia and fade into white screen then off .plz any solution |
10-28-2010, 07:22 | #6 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Last day i have faced this problem .I reflashed the fone but it shows nokia then white lcd and goes off . I opened the fone and washed it with petrol and rebo its pcb. Cleaned every point of lcd and its connector. My good luck it turns on and worked perfect . Try this may be ur prob be solved. |
10-28-2010, 08:39 | #7 (permalink) | |
Freak Poster Join Date: Jun 2010 Age: 36
Member: 1333709 Status: Offline Thanks Meter: 37 | Quote:
My friend ur good luck I Have 5 , 5130 and 2, 2700c is Same problem But no progress I think this is a common problem No solution 4 this | |
The Following User Says Thank You to solbh For This Useful Post: |
10-28-2010, 09:22 | #10 (permalink) |
Insane Poster Join Date: Oct 2010 Location: Gazipur,Bangladesh
Member: 1422587 Status: Offline Sonork: 100.1600692 Thanks Meter: 14 | hi to all gsm friend, i have problem fixing 5130 & 2700c phone even after flashing with latest files, still show nokia and fade into white screen then off .plz any solution |
11-23-2010, 18:16 | #13 (permalink) |
No Life Poster Join Date: Jun 2007 Location: dhaka,bangladesh
Member: 528679 Status: Offline Thanks Meter: 268 | hi to all it's a softwear problem just flash with hwk ufsx but when ui seting before backup crt then sx4 then ui after then write crt..........ur problem solved |
The Following User Says Thank You to sopnil For This Useful Post: |
12-21-2010, 05:42 | #15 (permalink) |
Crazy Poster Join Date: Sep 2010 Location: faruk
Member: 1387841 Status: Offline Sonork: faruk Thanks Meter: 32 | Originally Posted by amn32 Last day i have faced this problem .I reflashed the fone but it shows nokia then white lcd and goes off . I opened the fone and washed it with petrol and rebo its pcb. Cleaned every point of lcd and its connector. My good luck it turns on and worked perfect . Try this may be ur prob be solved. |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
