help 6820 keypads not working hi to all mates i have one 6820 that keypads are not working i have tried to all i can but failed to fix the phone pliz any one with the soluton asisst BR Shadow27 |
what is the history of the phone? have you try flashing it?try to replace crystal chips maybe this would help |
CPU comand key if you can remove the CPU doit maybe you will find some bad contact. |
Come to me this one after light wather damage and phone work perfectly withouth keyboards(all three).Have in the ultrasonic both cleaninig but always is same. Any solution? |
check flexcable, i have a 8620 and the cable are broken. |
6820 No Flex Cable Split In To 3 Parts Butt Also Chech Connector |
hi all i had a 6820 with slight liquid damage,the querty keys werent working,luckitly i bought a dead one,swapped the keys and it worked,i dont think that u can buy this querty module but if u can it sounds expensive,also check the little lead and plug ,which usualy goes on these! br farry |
