Old 06-01-2011, 15:26   #1 (permalink)
Member: 1455613
Sonork: 100.1605223
Thanks Meter: 55
help any body nokia 7610 restart
7610 on after 2 min restart. full flash ok ui setting ok but same problem.
Version Info:
SwVersion: V 2006_wk41 11-10-06 RH-51 (c) Nokia.
HW version: 7033
UEM version: 144
UPP version: 4225
Product Info:
Production serial number: PLD924837
Product code: 0514533
Module code: 0202215
Basic production code: 0528496
Product specific data: 000000000000
ATO: p?????????????????????????????????????????????????
Serial Numbers:
IMEI plain: 352274018115746
IMEI spare to net: 3A 25 72 04 81 11 75 04
IMEI SV to net: 33 25 72 04 81 11 75 34 F3
PDC: 4E 54 54 4A 50 12 34 56
Master code: 7403346201
Other Info:
Model: Nokia 7610 (Fashion Phone)
Project Name: Catalina
HW Details:
UPP: UPP WD2 v3.2E-n/a
UEM: UEME v2.0-n/a
RF: HELGO85G-n/a
Battery voltage: 4438 mV
Battery current: 190 mA
BSI: 2.4 KOhm
Imei net: 35227401811574
Version: SIMLOCKLIB VERSION 2.29
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000000005
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
The Following User Says Thank You to gsmbablu For This Useful Post:
Old 06-01-2011, 15:43   #2 (permalink)
Member: 1190352
Thanks Meter: 17
Tia The Han-format * + 3 + SEND BATON + Power Baton...................
The Following 3 Users Say Thank You to sriad For This Useful Post:
Old 06-01-2011, 16:35   #3 (permalink)
sharif28's Avatar
Member: 774718
Thanks Meter: 47
Chack sim or loos connection sim
The Following 2 Users Say Thank You to sharif28 For This Useful Post:
Old 06-02-2011, 08:24   #4 (permalink)
gsmjewel's Avatar
Member: 1311081
Sonork: gsmjewel
Thanks Meter: 117
7610 pm uploaded.
gsmjewel
full flash ub box
Attached Files 7610.rar (1,013 Bytes, 334 views)
The Following User Says Thank You to gsmjewel For This Useful Post:
Old 06-02-2011, 08:33   #5 (permalink)
Member: 762819
Thanks Meter: 232
Try it will definately solve ur problem
The Following User Says Thank You to farhannyb For This Useful Post:
Old 10-02-2011, 16:28   #6 (permalink)
salmaan shaik's Avatar
Member: 1271316
Sonork: 501101
Thanks Meter: 22
brother not please another solution its urgent thanks in advance
Old 10-03-2011, 04:32   #7 (permalink)
Registered User
Member: 1077541
Thanks Meter: 77
brother rehot board with flux.
Old 10-28-2011, 08:12   #8 (permalink)
Member: 1271316
Sonork: 501101
Thanks Meter: 22
brother re hot uem ic flash again hope solve ur problem
[Help] Vygis Box error EE06 on startup! (ANSWERED/SOLVED) vmobihcm VygisToolbox 15 09-14-2011 09:00
Spreadtrum Cpu con't unlock plz help...{SOLVED} saker2050 Dragon Box 2 06-01-2011 09:30
Nokia 5800 NPC Erase [Solved bySelf] thushdt Advance-Box 1 06-01-2011 07:52
Page generated in 0.16206 seconds with 9 queries
