Help Hardware n70 dead SOLUTION Help Hardware n70 dead SOLUTION [email protected]:D /??????????? |
say what is your problem.test your phone if connect with ufs3? connect to box remove autodetect product and click on check. post log. dont forget to say thanks. |
nokia only nokia not boot pls help me :confused::confused::confused: |
@GSMONNITIN Quote:
please explain your problem clearly |
N70 Dead only nokia pls help me :confused::confused::confused::confused::confused: :confused::confused::confused::confused: |
@GSMONNITIN Make format first if still Flash Mobile with latest and higher version????? Post Log here |
pls n 70 buzzer ways |
pls kindly request to give me full schematic diagram of n70 |
http://img20.imageshack.us/img20/2327/n701j.jpg http://img20.imageshack.us/img20/n701j.jpg/1/w352.png |
n72 dead hi i got a prob wid n72,,, wen charging, thn u can power on... but otherwise it wont. pwr switch ok... jumper from near retu ic,,, checked but it still not power on until charger attached... plzzzz can u help??? |
hi i got a prob wid n72,,, wen charging, thn u can power on... but otherwise it wont. pwr switch ok... jumper from near retu ic,,, checked but it still not power on until charger attached... plzzzz can u help??? [email protected] http://forum.gsmhosting.com/vbb/imag...ons/report.gif http://forum.gsmhosting.com/vbb/imag...tons/quote.gif |
post results |
check voltage on power switch ? ? ? ? If voltage not come then change display ic right one . post results voltage is coming... i hav already tried that lcd ic jumper,,,still no success... let me post my prob again in detail... n thnx for replyn bro,,, wen i attach d charger, thn i swichnon d cell and thn it gets on n works fine,,, but if i attach d charger wen it is on, thn it says not charging,,, n later wen i switch off n thn try to on again, it wont until i attach d charger,,, d battery terminal shows 1.6v wen charger attached... means dat d cel charges or shows charging wen off,,, otherwise in on condition it says not charging,,, im very badly stuck up in this prob since two days,,, |
check voltage on power switch ? ? ? ? If voltage not come then change display ic right one . post results i tried mate,,, but still it wont work,,, voltages r ok,,, |
