Old 07-12-2008, 19:02   #1 (permalink)
Member: 754396
Thanks Meter: 913
Arrow Help Hardware n70 dead SOLUTION
Help Hardware n70 dead SOLUTION [email protected] /???????????
The Following 4 Users Say Thank You to GSMONNITIN For This Useful Post:
Old 07-12-2008, 19:25   #2 (permalink)
Member: 157053
Sonork: 100.1606219
Thanks Meter: 489
say what is your problem.test your phone if connect with ufs3?
connect to box remove autodetect product and click on check.
post log.
dont forget to say thanks.
The Following User Says Thank You to morteza-icu For This Useful Post:
Old 07-13-2008, 15:29   #3 (permalink)
Member: 754396
Thanks Meter: 913
Thumbs up nokia
only nokia not boot pls help me
Old 07-13-2008, 15:37   #4 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
@GSMONNITIN
your mobile is dead/show only nokia logo
please explain your problem clearly
The Following User Says Thank You to KK Mobile For This Useful Post:
Old 07-14-2008, 15:56   #5 (permalink)
Member: 754396
Thanks Meter: 913
Red face N70 Dead
only nokia pls help me
Old 07-14-2008, 16:05   #6 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
first flash it with lateest firmware file.....
Old 07-14-2008, 16:07   #7 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
@GSMONNITIN
Make format first if still Flash Mobile with latest and higher version?????
Post Log here
Old 05-21-2009, 14:57   #8 (permalink)
Member: 569971
pls n 70 buzzer ways
Old 05-21-2009, 14:59   #9 (permalink)
Member: 569971
pls kindly request to give me full schematic diagram of n70
Old 05-21-2009, 15:36   #10 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
Bro.try it.
The Following 2 Users Say Thank You to mahbubalfa For This Useful Post:
Old 05-21-2009, 17:23   #11 (permalink)
Member: 1032503
Thanks Meter: 16
n72 dead
hi i got a prob wid n72,,, wen charging, thn u can power on... but otherwise it wont. pwr switch ok... jumper from near retu ic,,, checked but it still not power on until charger attached...
plzzzz can u help???
Old 05-22-2009, 14:15   #12 (permalink)
Member: 1032503
Thanks Meter: 16
[email protected]
Old 05-22-2009, 14:44   #13 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
Smile
[email protected]
check voltage on power switch ? ? ? ? If voltage not come then change display ic right one .
post results
Old 05-23-2009, 09:46   #14 (permalink)
Member: 1032503
Thanks Meter: 16
post results
voltage is coming... i hav already tried that lcd ic jumper,,,still no success... let me post my prob again in detail... n thnx for replyn bro,,,
wen i attach d charger, thn i swichnon d cell and thn it gets on n works fine,,, but if i attach d charger wen it is on, thn it says not charging,,, n later wen i switch off n thn try to on again, it wont until i attach d charger,,, d battery terminal shows 1.6v wen charger attached... means dat d cel charges or shows charging wen off,,, otherwise in on condition it says not charging,,,
im very badly stuck up in this prob since two days,,,
Old 05-23-2009, 09:50   #15 (permalink)
Member: 1032503
Thanks Meter: 16
post results
i tried mate,,, but still it wont work,,, voltages r ok,,,
All Blackberry Hardware and Software Solution youssef01 BlackBerry (RIM) 34 11-01-2012 17:31
Pls. Help-nokia n70-dead showing the following problem amit123 Nokia Hardware & Hardware Repair 21 08-14-2010 17:36
please help Nokia N70 mic solution abote didier Nokia Hardware & Hardware Repair 2 07-29-2010 07:48
Help please, n70 dead? it only display a blank screen. FabianAnarco Nokia Base Band 5 ( BB-5 ) 2 05-31-2007 17:47
Does anybody know to restore completely dead C 25 v 53? Hardware or software solution Jurik x1x to x45/x50 1 09-11-2000 12:49
Page generated in 0.23590 seconds with 9 queries
