Old 06-07-2007, 11:03   #1 (permalink)
Member: 256214
Thanks Meter: 10
help here for 7610 NOT CHARGING
7610 not charging
1-i used so many pm 6670 pm 7610 good pm ==>not work
2-i changed UEM upload rpl ==>not work
3-i changed all of the charging circuit (f130 v130 c134 c135 l)==>not work
4-made the charging way==>not work
5-remove GND resistor==>charing But after some second again NOT CHARGING.
i cant see what the problem is???
Old 06-07-2007, 11:23   #2 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
Flash With Jaf....
I Think Brthr It Is Soft Prblm ...if U Are Using Ufs Than Flash The Phn With Jaf And Use Higher Version File .....and Write Good Pm. After That If Problem Not Solve It Is The Problem Of Ugm...
Old 06-07-2007, 11:25   #3 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
try this pm done a few with this
Old 06-07-2007, 13:06   #4 (permalink)
Member: 172811
Thanks Meter: 135
just remove R135 and try if not , check battery bsi line if connected to R252.
Old 06-07-2007, 14:22   #5 (permalink)
..::Mr_Fone::..'s Avatar
Member: 364745
Thanks Meter: 719
hi m8t try this solution i hop it will be ok.
...:::Mr Fone:::...
Old 06-10-2007, 14:49   #6 (permalink)
Member: 256214
Thanks Meter: 10
thanks my freinds But non of u r solutions work
wolfgang Could u tell me where is those resistores???
I dont know is there a man like me in the world that have this kind of predicament???
SOS SOS SOS SOS SOS SOS ....
Old 06-10-2007, 20:15   #7 (permalink)
Member: 256214
Thanks Meter: 10
i guess there is No solution
THIS 7610 drive me up to the wall
Old 06-11-2007, 15:17   #8 (permalink)
Member: 172811
Thanks Meter: 135
As I See You Have The Service Manual!!!and You Did Not Search For This Resistors.any Way Here You R Marked With Red Line.
Old 06-12-2007, 05:06   #9 (permalink)
Member: 256214
Thanks Meter: 10
yes dead sure there is be...
thanks woolfgang i will check u r suggestion
Old 06-12-2007, 08:42   #10 (permalink)
Member: 364745
Thanks Meter: 719
yes very strang problem .................. anybody know this problem a perfact solution ...........
..::Mr Fone::..
Old 07-19-2007, 09:47   #11 (permalink)
Member: 408989
Thanks Meter: 21
Thanks pal. I just fixed it within a few seconds with your pm file. Great ! no more 'not charging' display on my screen now.
7610 not charge help meeeeee kondin25 Nokia Hardware & Hardware Repair 3 12-27-2007 19:00
help here for 7610 NOT CHARGING faridgsm3 Nokia Hardware & Hardware Repair 0 06-07-2007 11:02
7610 not charging bongiov Nokia Hardware & Hardware Repair 1 08-01-2005 17:15
7610 Not Charging after erase Faster Update WD2 & APE (Symbian Phones) 6 07-26-2005 08:55
nk 7610 not charging loverchew Nokia Hardware & Hardware Repair 1 06-28-2005 00:21
Page generated in 0.24319 seconds with 10 queries
