12-16-2009, 12:28 | #1 (permalink) |
Freak Poster Join Date: May 2007 Location: KERALA
Member: 517952 Status: Offline Sonork: Nisar mongaM Thanks Meter: 495 | Hello.. 5130c Contact Service Help.. My 5130c is showing Contact Service How Can Solve this plz Help me..!! InfoLog Below....!!!! MCU SW version: V 06.93 20-05-09 RM-495 (c) Nokia HW version: 2000 PCI version: RFIC version: 06540601 DSP version: ICPR72_09w04 LCD version: SEIKO PPM version: V 06.93 20-05-09 RM-495 (c) Nokia MH BT MCM version: 2222-143C Retu version: 16 Tahvo version: 22 Content Pack version: Content: mh_red V 06.93 20-05-09 RM-495 (c) Nokia Production serial number: IIN197203 Product code: Module code: 0204024 Basic production code: 0567772 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 353223030620067 IMEI spare to net: 3A 35 22 03 03 26 00 06 IMEI SV to net: 33 35 22 03 03 26 00 36 F5 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 |
12-16-2009, 12:55 | #4 (permalink) |
No Life Poster Join Date: Mar 2007 Location: IN FRONT OF YOU Age: 44
Member: 475440 Status: Offline Sonork: 1604067 Thanks Meter: 965 | repair your sl data by using any box your problem will solve Br Asghar Hussain |
The Following User Says Thank You to mobilecitycbk For This Useful Post: |
12-16-2009, 12:56 | #5 (permalink) |
12-16-2009, 13:24 | #8 (permalink) | |
No Life Poster Join Date: Jul 2008 Location: BHARAT Age: 42
Member: 823633 Status: Offline Thanks Meter: 1,705 | Quote:
reads info self test log here | |
The Following User Says Thank You to vaghubha_sodha For This Useful Post: |
12-17-2009, 08:50 | #9 (permalink) |
Member: 517952 Status: Offline Sonork: Nisar mongaM Thanks Meter: 495 | INFO_2ND : APE Chip Absent INFO_ALG : APE Chip Absent Rebooting Mobile IMEI : 353223-03-062006-7 SLserv: SIMLOCK SERVER SL_DATA Corrupted Process aborted How can...................?? plz I have only UFS & JAF plz help master... |
The Following User Says Thank You to snisar For This Useful Post: |
12-17-2009, 09:13 | #12 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: BANGALORE,KARNATAKA,INDIA
Member: 677987 Status: Offline Thanks Meter: 173 | Quote:
bro first flash with latest version n in jaff press unlock or if u have mx key then rpr sl u r prblm will besolved .INSHA***** | |
12-17-2009, 09:40 | #15 (permalink) |
Freak Poster Join Date: May 2007 Location: UAE
Member: 513874 Status: Offline Thanks Meter: 178 | Don't try with any box NO solution yet wait for NEXT good update........ One time i waste my 10logs to check 5130 contact service (SOlve) by MT-box but not working, Here is Logs Phone is in: Test mode Model: RM-495 (5130 Xpress Music) V 06.65/01-04-09/RM-495 (c) Nokia Production serial number IMM878707 Product code Module code 0204024 Basic production code 0567773 Flash code Order number Long production SN 0 MCU SW V 06.65/01-04-09/RM-495/(c) Nokia HW 2000 PCI RFIC 06540601 DSP ICPR72_09w03 LCD SEIKO PPM V 06.65/01-04-09/RM-495/(c) Nokia /SSA BT MCM 2222-143C Retu 16 Tahvo 22 Content Pack Content: ssa_b_blu/V 06.65/01-04-09/RM-495/(c) Nokia / IMEI: 35521203417xxxx WARNING: VPP pin is not connected, disabling VPP. V 06.65/01-04-09/RM-495 (c) Nokia IMEI: 35521203417xxxx Failed to Read V 06.65/01-04-09/RM-495 (c) Nokia IMEI: 35521203417xxxx Failed to Read V 06.65/01-04-09/RM-495 (c) Nokia IMEI: 35521203417xxxx Failed to Read 355212034178394 Searching loader rap3gv3_2nd.fg RAP3 Phone, Requesting... Requesting service authorization from server... busy, waiting... Requesting code authorization from server busy, waiting... Computing... busy, waiting... Sending RPL... C:\Program Files\GriffinTeam\MT-Box\rpls\35521203417xxxx_sim.rpl NO NPC CERTIFICATE!!!! IMEI: 35521203417xxxx SKIPPED Certificate sent ============= Set FBus mode for info ============= VBat is 4.03V Vpp pin has 0.10V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Test mode Model: RM-495 (5130 Xpress Music) V 06.65/01-04-09/RM-495 (c) Nokia IMEI: 355212034178394 Delay one second. Simlock send - FAILED! SuperDongle send - NO DATA IN RPL!!! V 06.65/01-04-09/RM-495 (c) Nokia IMEI: 3552120341xxxx Failed to Read Procedure completed in 54 seconds |
The Following 2 Users Say Thank You to greeney For This Useful Post: |
nokia 6303c contact service help.............. | RABIULSK | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 04-09-2010 21:18 |
nokia 6303c contact service help...... | RABIULSK | Universalbox | 5 | 03-30-2010 11:31 |
Nokia 5130c contact service Help.... | sonojee | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 03-28-2010 19:35 |
help 5130c contact service | ravindrapr | Nokia Hardware & Hardware Repair | 1 | 09-20-2009 07:41 |
5130c contact service pls help this kind of problem | justine54 | Nokia Base Band 5 ( BB-5 ) | 11 | 09-06-2009 20:09 |
