11-03-2006, 03:32 | #7 (permalink) |
No Life Poster Join Date: Sep 2006 Age: 41
Member: 356202 Status: Offline Thanks Meter: 46 | hey dude!!!!!!!!!!!!!! what did you do to your phone!!!! check your mcu version and ppm version...... do you really know how to flash a phone?..... theres a lot of solution for your phone but as you said you already replaced the four rams and it means then you should replaced UEM too... you cant flash your phone with mcu v5.30 and ppm 4.09... you must flash ppm with the same version as mcu..... well try that and post reply... luck dude WBR GSM_BLUE |
11-03-2006, 08:09 | #8 (permalink) |
Freak Poster Join Date: Jan 2005 Location: thailand Age: 44
Member: 106455 Status: Offline Sonork: not have Thanks Meter: 3 | yes,i use ppm not same mcu but when i chang mcu 5.30 and ppm 5.30 i have is same problem I think is hardware dammage and i need help from anyone Tell me how can repair my phone |
11-03-2006, 11:03 | #9 (permalink) |
Member: 106455 Status: Offline Sonork: not have Thanks Meter: 3 | Thank for every reply Now I can repair my 6600 is complete And I found Vio to D316 (IC flash) is not have When I connect Phone can flash and can power on not problem |
help me my 6600 killed after heat bluetooth ic | usama333 | Nokia Hardware & Hardware Repair | 19 | 06-28-2007 16:31 |
6600 writing error.help me my friends | jijeesh | UFS2 + UFS3-Tornadoflasher | 2 | 08-07-2006 15:57 |
help me my 6600 is white screan now!! | .:bono:. | WD2 & APE (Symbian Phones) | 4 | 02-25-2006 22:31 |
Hello pls help me My motorola Sp lock help me | varma raj | Motorola ODM | 1 | 06-19-2003 22:39 |
Pls help me my siemens c-35 keypad Hang pls help me | varma raj | x1x to x45/x50 | 1 | 06-17-2003 10:50 |
