Old 03-28-2007, 05:51   #1 (permalink)
Crazy Poster
Member: 123061
Thanks Meter: 2
Cool help me my 6600 killed after heat bluetooth ic
my 6600 was not turn on bluetooth and i can not galary then i decide to heat on bluetooth ic after all that my phone is not turn on it is dead after that i flashed the version 5.53 he refuse the flashing till i skip bluetooth after finising of flashing my phone is not power on , with knowledge that it take mcu +ppm only and without bluetooth flashing help meeeeeeeeeeeeeeeeeeeeeeeeee please
Old 03-28-2007, 05:57   #2 (permalink)
jaggi's Avatar
Member: 258480
Thanks Meter: 14
i think u heated the module too much & ic one of them get shorted now u have to replace the module with another dead phone.another option is remove module & check ur phone gets power on or not...then post results...............
Old 03-28-2007, 05:59   #3 (permalink)
Member: 248086
Thanks Meter: 22
sir try to replace the bluetooth ic may be it's shorted
Old 03-28-2007, 06:21   #4 (permalink)
keaelite's Avatar
Member: 288470
Sonork: 100.1605122
Thanks Meter: 664
follow th proced what they said remove bluetooth and try to switch on
Old 03-28-2007, 06:25   #5 (permalink)
Crazy Poster
Member: 123061
Thanks Meter: 2
of course i removed bluetooth ic but phone can not power not help me please
Old 03-28-2007, 07:09   #6 (permalink)
Member: 367928
Thanks Meter: 178
Dear after removing bt ic flesh the fone if ok then it may also powr on but if flesh problem . then u may give extra heat on bt and other side is uem may be uem is infected try rebol uem
Old 03-28-2007, 07:20   #7 (permalink)
Crazy Poster
Member: 123061
Thanks Meter: 2
what do you mean rebol uem? please help me
Old 03-28-2007, 07:32   #8 (permalink)
.::koolfriend4u::.'s Avatar
Member: 200145
Sonork: 100.1596786
Thanks Meter: 677
i think u heated d bluetooth module too much...so wat happend is,d othr side of d board...UEM IC wll b there...probably UEM is damaged now..
soo sad to hear this...
Old 03-28-2007, 07:44   #9 (permalink)
Member: 367928
Thanks Meter: 178
try to change r rebool uem but risky
Old 03-28-2007, 07:49   #10 (permalink)
Crazy Poster
Member: 123061
Thanks Meter: 2
i can write mcu and ppm and ican,t write pm and i can not set factory setting my phone is dead help me
Old 03-28-2007, 07:58   #11 (permalink)
keaelite's Avatar
Member: 288470
Sonork: 100.1605122
Thanks Meter: 664
try to reheat UEM..................
Old 03-28-2007, 08:25   #12 (permalink)
Member: 121932
take out bluetooth reflash with v5.27 and post the resolt.i have an 6600 good to change language when i flashed with 5.53 the phone won't torn on but when i flashed with 5.27 all was good.i think this is a missmatch of the platform with v5.53 because some work with 5.53 some not.waitting for resolt!
Old 03-28-2007, 08:31   #13 (permalink)
Member: 367928
Thanks Meter: 178
iif reheat doesnot help u then replace uem at ur own risk
Old 03-28-2007, 08:41   #14 (permalink)
Lhick's Avatar
Member: 333359
Thanks Meter: 91
Under BT is UEM, you might damage it Mate. Check UEM.
Old 03-28-2007, 08:52   #15 (permalink)
Crazy Poster
Member: 123061
Thanks Meter: 2
how check uem by voltmeter without heat or change because it is danger
help me my c975 killed by ultima box usama333 Ultima Box Light 6 03-25-2007 05:54
Help me My 6600 supotohsot Nokia Hardware & Hardware Repair 12 11-05-2006 11:32
help me my 6600 is white screan now!! .:bono:. WD2 & APE (Symbian Phones) 4 02-25-2006 22:31
Nokia 6600 killed after flash juanjo7812 Federal One 3 01-01-2005 21:37
help me my s 40 after flash is dead lelik NON Siemens Brand (ODM Phones) 2 04-24-2003 19:04
Page generated in 0.21905 seconds with 10 queries
