05-15-2010, 21:54 | #1 (permalink) |
Registered User Join Date: Aug 2009
Member: 1087294 Status: Offline Thanks Meter: 252 | help nokia 1112 ime ?????????? i have jaf and ufs now set power on in insert sim with sim showing sim not valid what to do plz guide me help me imei ????????????????? |
05-17-2010, 03:23 | #4 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Sri Lanka
Member: 576633 Status: Offline Thanks Meter: 392 | Go to UFS and,chack tha phone get tha Info, now prss Rd UEM butten,now u can see massge Readout and Use UEM IMEI ? --- clik Yes, now u can see genareted rpl file save it your desktop, Edit IMEI number massege, just clik ok ! Edit Product Cord massege type your phone back side stiker product number and ok ! UEM Changed ? massege use number "0" and ok ! Edit dongal massege Just clik ok ! now save the file now prss WR UEM butten canfarm "are U Ab......... " massege Yes ! it ask rpl file, then select your desk top rpl file Just like named 356xxxxxxxxxxx_generated.rpl file, and press yes ! now Get Info ! u can see ur phone now OK.... So dont forget to thanks To me ! |
The Following 2 Users Say Thank You to nishue For This Useful Post: |
08-01-2010, 19:17 | #8 (permalink) |
Registered User Join Date: Dec 2006 Location: Shakar Garh To Kmk.Gujranwala Age: 12
Member: 407063 Status: Offline Thanks Meter: 2,133 | HWK V2.10.00 New Feature DCT4-WD4 RPL Generating system. is this working???....Should to check....i am trying and posting result. :PHONE INFO: MCU SW : V 7.02 10-12-07 RH-93 (c) NMP PPM SW : V 7.02 10-12-07 RH-93 (c) NMP IA Prd.Code: 0532991 Bpr.Code: 0532665 Prod.Sn : VF2960232 HW Vers : 0502 UEM : 1328 UPP : 8705 [2201] RFIC Ver: 0500 DSP Vers: P05w06.v34 LCD Type: WIN:SYRS:01 ST7506 IMEI : ??????-??-??????-? SL Conf : 3B4-CF-0464F899AFA SL Prof : BA872D30B401489-8 SL Var : 0000FFFFFFFFFFFFFFFF SL Aux : 00023F3F HW Sig : 1EB9620C23533E2B Box Id : 0000000000000000 Bad SL Structure BC: 00 MastCode: ? Provider: Not Found #pw+ 858 091 271 672 107 +1# #pw+ 839 831 550 720 745 +2# #pw+ 887 431 501 536 043 +3# #pw+ 189 924 107 741 430 +4# #pw+ 747 050 363 502 464 +5# #pw+ 334 556 752 257 361 +6# #pw+ 019 913 636 711 724 +7# Reading UEM Warning, IMEI/ESN Backup Fail IMEI Number: ??????-??-??????-? 1st Boot: Ok, DCT4, UPP: 2201 [Rh-93] [2.1.0.1] 2nd Boot: u_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00EC2268,Sam K8S3215ETE Algorithm: u_amd.fia, , Ver: 4.79.0 UEM IMEI Num : 358068-01-765694-8 00000000: 41 F9 33 C5 FF FF 4A 45 14 32 17 31 76 33 85 60 A.3...JE.2.1v3.` 00000010: 08 71 56 96 F4 FF FF FF FF FF FF FF FF 00 00 8F .qV............. 00000020: 34 FF FF FF FF 00 15 EB 4....... 00000000: CD 2D C3 52 D8 95 B9 FA F7 E2 39 B1 49 08 3A E0 .-.R......9.I.:. 00000010: 46 6D 77 C6 DE 98 92 1A 35 16 12 02 8A 72 3D BC Fmw.....5....r=. 00000020: FE EA CF 60 56 74 8C 6D ...`Vt.m Ask IMEI Num : 358068-01-765694-8 Product Code : 0532991 UEM Changed : 0 Dongle S/N : 038442 1st Boot: Ok, DCT4, UPP: 2201 [Rh-93] [2.1.0.1] 2nd Boot: u_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00EC2268,Sam K8S3215ETE Algorithm: u_amd.fia, Ver: 4.79.0 ASIC Detected: 2 UEM Read Done, Time: 00:01 Writing UEM IMEI: ??????-??-??????-?, ASIC: 2 RPL File Info: IMEI: 35806801765694 CHCK: 7502 Warning: No DATA2 Record IMEI: ? PROD: ? 1st Boot: Ok, DCT4, UPP: 2201 [Rh-93] [2.1.0.1] 2nd Boot: u_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00EC2268,Sam K8S3215ETE Algorithm: u_amd.fia, Ver: 4.79.0 UEM Writing Done, Time: 00:02 Warning: No SIM_PROG_DATA in File AFTER UPLOADING GENERATED RPL FILE MCU SW : V 7.02 10-12-07 RH-93 (c) NMP PPM SW : V 7.02 10-12-07 RH-93 (c) NMP IA Prd.Code: 0532991 Bpr.Code: 0532665 Prod.Sn : VF2960232 HW Vers : 0502 UEM : 1328 UPP : 8705 [2201] RFIC Ver: 0500 DSP Vers: P05w06.v34 LCD Type: WIN:SYRS:01 ST7506 IMEI : 358068-01-765694-8 SL Conf : 001-01-00000000000 SL Prof : 800000000001000-2 SL Var : 00003580680176569400 SL Aux : 00023031 HW Sig : 1EB9620C23533E2B Box Id : 8BD2FFFFFFFFFFFF BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN MastCode: 14 32 17 31 76 Provider: GSM Test Equipment #pw+ 784 160 000 253 072 +1# #pw+ 042 103 262 063 517 +2# #pw+ 047 543 560 567 650 +3# #pw+ 097 153 412 523 666 +4# #pw+ 148 244 666 644 653 +5# #pw+ 939 432 354 746 344 +6# #pw+ 405 207 420 374 411 +7# UNLOCK PROCESS NEEDED IMEI: 358068-01-765694-8, ASIC: 2 FILE: rh93_07.020 1st Boot: Ok, DCT4, UPP: 2201 [Rh-93] [2.1.0.1] 2nd Boot: u_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00EC2268,Sam K8S3215ETE Algorithm: u_amd.fia, Ver: 4.79.0 Algorithm Ok, MSID: 84C142B14A59423AA22CB0B03E Decoded MSID: 3E4EBAE9-008C573F-AA000000 Encoded FAID: 06FBB1B0-08EA170E-0E30107E Area1: 0x01140000-0x0115FFFF Erased, Time: 00:00 PAT Flashing Completed, Time: 00:00 IMEI: 358068-01-765694-8, ASIC: 2 SimLocks Initialized (Patch Ok), Time: 00:00 1st Boot: Ok, DCT4, UPP: 2201 [Rh-93] [2.1.0.1] 2nd Boot: u_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00EC2268,Sam K8S3215ETE Algorithm: u_amd.fia, Ver: 4.79.0 Algorithm Ok, MSID: 84C142B14A59423AA22CB0B03E Decoded MSID: 3E4EBAE9-008C573F-AA000000 Encoded FAID: 06FBB1B0-08EA170E-0E30107E Area1: 0x01140000-0x0115FFFF Erased, Time: 00:00 UNP Flashing Completed, Time: 00:00 SimLocks Initialized, Time: 00:42 UI Defaults Ok, Time: 00:04 Set UI Factory Defaults Ok, Time: 00:00 Set Full Factory Defaults Ok, Time: 00:00 Set Software Upgrade Defaults Ok, Time: 00:00 Set Security Ok, Time: 00:00 Init Normal Mode Failed, no SIM Card NOW PHONE WORKING WELL WITH ORIGINAL DATA MCU SW : V 7.02 10-12-07 RH-93 (c) NMP PPM SW : V 7.02 10-12-07 RH-93 (c) NMP IA Prd.Code: 0532991 Bpr.Code: 0532665 Prod.Sn : VF2960232 HW Vers : 0502 UEM : 1328 UPP : 8705 [2201] RFIC Ver: 0500 DSP Vers: P05w06.v34 LCD Type: WIN:SYRS:01 ST7506 IMEI : 358068-01-765694-8 SL Conf : 001-01-00000000000 SL Prof : 800000000001000-2 SL Var : 00003580680176569400 SL Aux : 00023031 HW Sig : 1EB9620C23533E2B Box Id : 894F8BD2FFFFFFFF BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN MastCode: 14 32 17 31 76 Provider: GSM Test Equipment #pw+ 784 160 000 253 072 +1# #pw+ 042 103 262 063 517 +2# #pw+ 047 543 560 567 650 +3# #pw+ 097 153 412 523 666 +4# #pw+ 148 244 666 644 653 +5# #pw+ 939 432 354 746 344 +6# #pw+ 405 207 420 374 411 +7# it means it working well............... i checked some DCT4+ and some WD2 phone not working well,you should to check by your self...i will also post result...... Thanks |
08-01-2010, 19:26 | #9 (permalink) |
Member: 407063 Status: Offline Thanks Meter: 2,133 | how DCT4-WD4 RPL Generating system by hwk see video YouTube - repair imei for DCT-4 by HWK_video_by_zopo.wmv |
The Following User Says Thank You to naeem_skg786 For This Useful Post: |
08-01-2010, 19:40 | #10 (permalink) | |
Freak Poster Join Date: Feb 2008 Location: india Age: 42
Member: 714489 Status: Offline Thanks Meter: 31 | use mxkee---hwk Quote:
use my id 100% solv?????????????? pm | |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
