02-08-2011, 04:01 | #1 (permalink) |
Freak Poster Join Date: Aug 2008
Member: 828494 Status: Offline Sonork: kruger selection Thanks Meter: 18 | help x6 vibrate only and will not power on |
The Following User Says Thank You to tol4ray For This Useful Post: |
04-22-2011, 22:52 | #2 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Ro Age: 43
Member: 126197 Status: Offline Thanks Meter: 26 | at first attempt to power on it only vibrate but if you try again in a few seconds does it vibrate again or you have to remove battery to vibrate again at power on ? if it vibrate every time you try to power on without replace battery I think it's HW problem (BSI) , if it hangs after first attempt and only if you remove battery and try again it vibrate again I think it's SW problem... I have one too... mine vibrate once and won't do anything until remove battery... ANYONE can help me ? please. |
04-23-2011, 08:42 | #4 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Bangladesh Age: 38
Member: 1003058 Status: Offline Sonork: 100.1589274/mahbubalfa Thanks Meter: 26,433 | Quote:
2.try to flash same prodact code. 3.rehot rap ic. try this solution one by one. | |
04-26-2011, 19:41 | #6 (permalink) |
No Life Poster Join Date: Nov 2008 Location: saudi arabia
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | i think first of all, u need to flash yr phone with eno files,, and then reflash yr phone with latest firmware and same product, post result,, if still,,check hardware reball rap,,also check, boot ic, bsi line,, plzzzzzzz must post yr phone flashing logs with self test and info,if possible |
The Following User Says Thank You to alkhaleejmobile For This Useful Post: |
05-02-2011, 07:43 | #7 (permalink) |
Member: 126197 Status: Offline Thanks Meter: 26 | x6 only vibrate so far I try to flash it several times including flash with ENO file or USB flashing with cyclone and mxkey phone was v30.0.3 when it came to me but I can't find sw with same product code v30.0.0 or 31.0.4 so I reflash it with 30.0.3 , same problem . Then I try 31.0.4 , nothnig new... then ENO , nothing new then USB , nothnig new Checked BSI - is OK Checked + Lines - all ok Try other batteryes - nothnig new Checked current consumption when power up - seems to be the same as a good working set PCB is looking good , no wather damage , no torsion , set looks as new... try to remove camera like some peoples say on this forum - still only vibrate try other LCD like some peoples say on this forum - still only vibrate try to power up only with lcd connected - still only vibrate the set is able to enter TEST or LOCAL mode only with box , flash seems to be ok , no error the set won't power up when charger is inserted at power up it vibrate BUT it won't vibrate if i try power up again untill I remove and reinsert battery ! (I tryed with a good one to isolate BSI and it vibrate every time I press power on so I eliminate BSI problem like that) now... if someone has an answer to this problem is welcome to help ! here is the log : first one is info and shows actual status of the phone and second is more complete and shows initial status , flashing logs more status etc Last edited by Steamroller; 05-02-2011 at 07:46. Reason: post flashing log |
08-08-2011, 12:02 | #10 (permalink) | |
Freak Poster Join Date: Jul 2003
Member: 33954 Status: Offline Thanks Meter: 10 | same problem here any help is welcome Quote:
01-05-2012, 18:30 | #14 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | x6 vibration only when turn on-but in ufs set on and info ok-details as below MCU SW : V ICPR72_10w42.1.2 17-03-11 RM-559 (c) Nokia APE Core: V 32.0.002 APE Var : V 32.0.002V 32.0.002 V 32.0.002 Product : Nokia X6-00 Prd.Code: 0580466 Bpr.Code: 0589312 Prod.Sn : CWD723985 HW Vers : 1123 APE HW : 256 APE Adsp: 256 EM VILMA: 16 EM BETTY: 22 RFIC Ver: |Vapaus_5.1 | Aura_?.? DSP Vers: ICPR72_10w33 WLAN Id : A0 4E 04 13 66 0A IMEI : 352006-04-543474-4 SL Serv : SIMLOCK SERVER SL Conf : 244-07-00000000000 SL Prof : 0000000000000000 SL Count: 00 00 BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: Nokia Test;Finland set on menu come when connect to ufs-so i think it due to betty or avilma problem.customer set it occured during charging-so i think it betty problem. am i right? can i replace it from n73? |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
