10-05-2005, 20:20 | #1 (permalink) |
Freak Poster Join Date: Mar 2001 Location: Australia Age: 41
Member: 3671 Status: Offline Thanks Meter: 28 | Here is the specification sheet of bga underfilling used in Nokia mobile phones! After a lot of research I found wich type of underfilling is used by glued BGA's in Nokia mobile phone. See their technical sheets attached. Loctite 3566 is removea ble, melting point is 190 degrees celsius. At this temperature te TG value's changed. Loctite 3567 is not remove able Note, officially seen Nokia service centers are not allowed to remove glued BGA's and they have to swap the board so removing glued BGA's is a riskfull operation! Good luck. |
The Following User Says Thank You to alro For This Useful Post: |
Here is the complete details of bb5 unlocking with ub | Miftahudin | Universalbox | 1 | 03-13-2009 22:51 |
Here is the new look of samsung lang info | tsarkh | Samsung Flashers, Software, Firmware. | 1 | 10-22-2008 13:37 |
here is the big pb of the year | asco777 | FuriousGold | 4 | 03-24-2008 09:38 |
here is the latest version of S.E TOOL 10000% full | muhammad irshad | SETool2 | 1 | 06-26-2007 13:40 |
Here is the source code of the Smalles Crack for winddp v3... | AboAli | GSM Programming & Reverse Engineering | 5 | 07-23-2002 18:48 |
