10-19-2006, 02:15 | #1 (permalink) |
Freak Poster Join Date: May 2005 Age: 45
Member: 143156 Status: Offline Thanks Meter: 95 | Hii All 6670 Is Hang Any Solution Pls I Flashing Full Flash And I Heating Uem + Cpu + Both Flash But No Sloved Replace Uem And Smaal Flash Ic But No Sloved Showing Local Mod After Flash And Uisetting And Format Is Ok But Problem Is Stil Pw On Is Ok After Showing Nokia White Lcd And Hang Some Times Write Memory Full And Hang After 2-3 Sec Please Help Any Solution |
10-22-2006, 16:56 | #7 (permalink) |
Insane Poster Join Date: Sep 2006 Location: rest of world
Member: 354903 Status: Offline Thanks Meter: 10 | hello heat to bluetooth ic ur problem for bluetooth. first try it by bt flashing if not work then heat, if ur problem is still then try from heating to mjolner ic, try it good luck replay after sol. |
10-22-2006, 20:35 | #8 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: Egypt Age: 52
Member: 129676 Status: Offline Thanks Meter: 39 | Quote:
12-26-2006, 22:30 | #10 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: iraq
Member: 231662 Status: Offline Sonork: 1607488 Thanks Meter: 390 | It Is May Sdram Quote:
I HAVE LIKE THIS PROBLEM IT IS SOLVED BY SDRAM www.gsmjoman.com TC | |
j750i hang!!!!any solution??? | iceman_27 | UST Pro II | 1 | 02-04-2009 10:15 |
N82 white lcd ? Hang ? Any solution ? | .:RoMeO:. | Nokia Hardware & Hardware Repair | 1 | 02-02-2009 12:18 |
My Multibox allways startup hang any solution ? | kabirhossain | Multi-Box | 5 | 05-27-2008 06:56 |
is there any solution for solving picture message hanging after nk_calc | sidharthaharish | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 03-01-2002 14:49 |
Is there any solution in 3310 all 4 lock are close? | raivenz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 07-21-2001 01:24 |
