Old 10-22-2005, 11:48   #1 (permalink)
rajiv007's Avatar
Member: 78767
Sonork: 100.95137
Thanks Meter: 566
How to check dct3 dead phone hardware with the help of software like banana
How to check dead phone hardware with the help of software like banana
How to check hager for dead phone any jumper .
please help
Old 10-24-2005, 10:04   #2 (permalink)
rajiv007's Avatar
Member: 78767
Sonork: 100.95137
Thanks Meter: 566
anyone who is expert help me
Old 10-24-2005, 19:08   #3 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 829
@ rajiv007,
pm me with your detail
w.b.r.
Old 10-25-2005, 08:30   #4 (permalink)
rajiv007's Avatar
Member: 78767
Sonork: 100.95137
Thanks Meter: 566
Originally Posted by baraka42
@ rajiv007,
w.b.r.
i don't get you please explane me more
Old 10-25-2005, 12:28   #5 (permalink)
Member: 110065
Thanks Meter: 25
Software to use for finding fold on dct3 dead phone.
Rollas 477 flasher.
Connect dead phone press read button, power on and see what error message
is given.
1-Ram bad (is 90% Flash ic 10% cpu.)
2-Must reseve ---------but get ----------(ccont)
3-look at left bottom of flash program if message done(hagar or 13mhr christall)
Hope this will help.
Old 10-25-2005, 16:14   #6 (permalink)
rajiv007's Avatar
Member: 78767
Sonork: 100.95137
Thanks Meter: 566
thanks mikie274 thanks a lot
but there are 2 types of 'done' one is very quilcky, other is after 2 sec
what is dif
Old 10-26-2005, 16:07   #7 (permalink)
Member: 18057
Thanks Meter: 64
here is the soution
1 tx line ow for boot strip begin--- mean hager or 26mhz fault check 2.8v
at 26 mhz. check hagar lines or hagar faulty
2 NHM 5 preloder counter respond ERROR -- check flashing voltages.
3 must received --- vpp,vbat ------mean check ram ics.b5 is open.
Old 10-26-2005, 17:25   #8 (permalink)
baldev's Avatar
Member: 153805
Thanks Meter: 324
for dead phones first check supply to all sections, vsin1, vsin2, vcore etc.check supply to 26Mhz. oscillator.If you have a oscilloscope you can check clock signal to cpu (13Mhz).If 26Mhz crystal is ok check hagar supply.
Old 10-29-2005, 16:36   #9 (permalink)
Member: 161796
here is some...
1.tx line low for bootstrap begin
a.ccont and circuit
b.hagar &circuit
c.crystal osci
d.clock crystal
e.cpu
2. preloader boot error
a.loose connection between cable and phone,mostly terminal
b.hagar
c.crystal osci
d.cpu
3.phone ram is bad
a.ram itself
b.flash i.c
c.cpu
4.unknown flash? of course flash ic
5.not accept algorythm code
a.loose battery terminal connection
b.ccont
c.flash ic
6.battery voltage is too low
a.low supply
b.flash i.c
c.ccont
7.flash erasing error
a.low supply
b.flash i.c
c.ccont
d.cpu
8.power off mobile first and then connect
a.loose connection between phone and flasher, or batterry no charge.
b.open line between positive and ground
c.shorted between + and -
9.power on shortly
a.bad switch, use charger to trigger if does not respond then..
b.ccont
c.shorted components,hang other components to test.
d.cpu
10.successfull flash programming but program undetectable.
a.ram
b.flash ic.
hope it helps...
br..
Old 10-29-2005, 17:34   #10 (permalink)
rajiv007's Avatar
Member: 78767
Sonork: 100.95137
Thanks Meter: 566
thanks thanks thanks
hope meybe you have for dct4 (UFS-GRIFEEN) please share
Old 10-30-2005, 12:25   #11 (permalink)
rajiv007's Avatar
Member: 78767
Sonork: 100.95137
Thanks Meter: 566
what about wintesla for network and other please help
service Nokia phones with the help of schematic/manual .:::Dr. Cell:::. Nokia Hardware & Hardware Repair 2 03-30-2010 18:04
L700 dead How to check after charge phone Dead Babyunlocker Samsung Hardware Repair 0 11-17-2009 10:13
Data Transfer with the Help of CDMA Phone prasmin Nokia CDMA 0 10-20-2007 17:22
HOW TO REPAIR A DEAD PHONE WITH UST Pro2??? Eagle7 UST Pro II 1 08-19-2006 02:50
HOW TO REPAIR A permanent BOOT_LOADER MESSAGE on the screen of phone Eagle7 Smart-Clip 14 05-31-2006 20:18
Page generated in 0.92254 seconds with 8 queries
