Old 12-02-2004, 15:57   #1 (permalink)
yui
yui's Avatar
Member: 7528
Thanks Meter: 40
how convert 8390>8310
i not find soliution for 900mhz
Old 12-03-2004, 23:08   #2 (permalink)
yui
yui's Avatar
Member: 7528
Thanks Meter: 40
nobody nows?????????????????????????????
Old 12-03-2004, 23:48   #3 (permalink)
Member: 45682
Thanks Meter: 54
hi
try this work
br
Old 12-04-2004, 00:00   #4 (permalink)
yui
yui's Avatar
Member: 7528
Thanks Meter: 40
This For 1800 Not 900mhz!!!!
Old 12-04-2004, 00:45   #5 (permalink)
Member: 6358
Thanks Meter: 10
8390 only has 1900MHz band, with conversion it will work at 1800 MHz, what do you expect more?
Old 12-04-2004, 02:52   #6 (permalink)
yui
yui's Avatar
Member: 7528
Thanks Meter: 40
in my country no 1800mhz!!
Old 12-15-2004, 12:00   #7 (permalink)
Member: 81192
8390>8310
is step 3 necessary? anyway, i've tried ur solution so far and i replaced the VCO with a VCO from a 5210 and i still don't have a signal. but, i think it's working because before conversion i tried manual network searching and the message reads "NO NETWORK ACCESS" and after conversion the message reads "NO NETWORK COVERAGE" which means that the converted phone has weak receiver. anyway, my question is what is the best VCO to replace the 8390's VCO. thanks for the solution. salaam.
Old 12-17-2004, 12:37   #8 (permalink)
calvinpower's Avatar
Member: 14229
Thanks Meter: 135
vco of 5210 is same as 8310
Old 12-19-2004, 10:22   #9 (permalink)
Member: 81192
thanks, i've checked it and you're right.. i must have used a faulty VCO.. anyway, i'll post any progress.
Old 03-30-2005, 11:05   #10 (permalink)
Registered User
Member: 44779
Thanks Meter: 4
Hi!
So, is there any sollution to convert a 8390 to a 8310 with both 1800 and 900Mhz, or just 1800Mhz.
And please can somebody put out a better quality picture and write down what to do exactly?
Thanks!
WBR. Atter
Old 03-24-2007, 10:17   #11 (permalink)
kashifshehzad's Avatar
Member: 221463
Thanks Meter: 179
plese send me clear pic for chang 8390 to 8310 thanks in advance
Old 06-10-2009, 16:41   #12 (permalink)
Registered User
Member: 726546
Sonork: 100.1578784
Thanks Meter: 555
i need 8390 convert solution for 900mhz frequency
How convert hex (TAU) to hex (full emmi)? audi_tt Motorola Old Legacy (EMMI) 4 12-08-2002 10:52
how convert c2r file to xbi ? adypet x1x to x45/x50 2 12-01-2002 08:20
ALCATEL: How convert Latin <-> Complex flash? jordik GSM Programming & Reverse Engineering 1 10-03-2002 09:32
How convert C2R file in XBI format adypet x1x to x45/x50 0 07-08-2002 01:26
who can tell me how convert bin format to siemens *.xbi format? winers x1x to x45/x50 5 08-27-2001 19:49
Page generated in 0.22919 seconds with 10 queries
