04-22-2007, 06:10 | #1 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 205738 Status: Offline Thanks Meter: 129 | how to fix "shorting" fault ..... but how to find in 3220,6070,3230,6630,N72..etc As i checked never find shortening in pfo.... pl.give here possible causes which may help to solve such problems.. Wbr... |
04-22-2007, 13:35 | #2 (permalink) |
Freak Poster Join Date: Apr 2007 Location: INDONESIA
Member: 486960 Status: Offline Thanks Meter: 45 | In DCT4 the are more possibility component that may cause "Short" fault. But the most simple way is use Power supply and seek the component that overheated.... wish you luck |
12-11-2007, 19:47 | #4 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Ngemut Penthil
Member: 295100 Status: Offline Thanks Meter: 212 | only tips for shorting: dont ever remove PF(PA) before remove L(induktor) before PF, its + to PF. if remove this L and short gone, damage 100% PF. most Nokia have this L. if remove and still short, its no PF damage. try find C(capasitor) filter, open diagram, this conect both + and ground (ex: in charging circuit after L). maybe more five C with this position, but diferent place, try remove one by one and check. final, try connect with batrey and touch all component, whereis hot, this area is short. maybe help BR bocahklaten |
12-12-2007, 10:50 | #6 (permalink) | |
Freak Poster Join Date: Apr 2005 Location: INDIA Age: 43
Member: 138224 Status: Offline Thanks Meter: 56 | Quote:
How to trace a fault with multimeter | maria007 | Various | 1 | 12-22-2009 15:41 |
<<< 7210c Contact Service - How to Fix This Fault >>> | khadim100 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 12-05-2009 08:20 |
F200 User Fault On Illegal Trial and NO NETWORK how to fix? | jap_line | UST Pro II | 1 | 11-23-2009 15:54 |
SO nobody knows how to repair this fault? | nickemac | Samsung Hardware Repair | 0 | 05-30-2006 18:57 |
how to fix 02x2 camer prob. due to flash | s4sajii | Redbox | 5 | 10-19-2004 14:07 |
