Old 07-13-2004, 07:06   #1 (permalink)
Registered User
Member: 39208
Thanks Meter: 152
How to flash N-GAGE ..?
Hi..
Have nokia N-GAGE dead ..., when i power it on , i see only nokia apear on lcd then disapear ...,
i'm tring to flash it with griffin box ,
i want to know , what ppm file shall i use ...?
i try many of them but after flashing the phone can not powers on
here is what griffins says :
Initializing Phone...
Boot and Flash loaders operation took 10.795001 seconds
Erasing - erase took 175.252008 seconds
Flashing MCU - flashing took 367.348017 seconds
Erasing - erase took 13.840001 seconds
Flashing PPM - flashing took 20.980001 seconds
Flashing DONE
After flash processing...
Trying autopower
Fail
note that ppm flashing took only 20 sec., it do it very fast ....
the speed bar goes very very fast ....
pls help
Old 07-13-2004, 09:04   #2 (permalink)
Cheater -Don't Deal with him-
Member: 21296
Thanks Meter: 328
Don't open a new thread for a topic that is very much discussed earlier, search before you make a new thread.
http://forum.gsmhosting.com/vbb/show...wing+only+logo
Old 07-13-2004, 09:35   #3 (permalink)
Registered User
Member: 39208
Thanks Meter: 152
actually i search over this forum and i do all these steps ...but i did not succeed ...
and way ..., when i flash the mcu ppm ..., now i can not turn on the phone and only white screen ..., so i can not also format user area ...ok...,
if someone can help it is apriciated ...
and also after flashing griffin says " griffin failed to communicate with the phone and phone did not auto power , power on phone and press yes to continue ,no to abort phone mode change "
also i did try to format user area ...but griffin says Format User AreaNo communicationFAIL
pls help
BYTE
Old 07-13-2004, 16:43   #4 (permalink)
Registered User
Member: 39208
Thanks Meter: 152
another thing ...,
i connect the battery terminals to the phone directly ..., now i can reset full factory setting and format user area ..., but the same only nokia logo then disapear ...!!!
but format user area only took 1 sec .... normal ...?
and when flashing ppm file the progress bar jump from the first step to the last in one step ....the wait about 10 sec., then flashing done ...also normal ...?
pls help me
Old 07-14-2004, 17:56   #5 (permalink)
Registered User
Member: 39208
Thanks Meter: 152
pls help ....
need help urgently ..
Old 07-17-2004, 05:14   #6 (permalink)
Nhatcuong's Avatar
Member: 7782
- flashing this "NEM4_ERASE32mb.bin" , PPM only, phone will be die
- full flashing MCU+PPM, lowest version nem433.0c1
- write PM> unlock> format user area.
all done.
Old 07-17-2004, 06:58   #7 (permalink)
Registered User
Member: 39208
Thanks Meter: 152
i just want to know .... what is the PM ..?
Old 07-19-2004, 18:24   #8 (permalink)
Registered User
Member: 39208
Thanks Meter: 152
pls help . need help urgent
Old 07-19-2004, 18:36   #9 (permalink)
ROBISH_GSM's Avatar
Member: 60523
Thanks Meter: 9
TRY TO FLASH IT FULL FLASH MCU+PPM and then get it pm value and the last formating user erea 3times
pmm (languge)
pmvalue for charging+light _network+.........................etc
i hope that i help u
Old 07-19-2004, 18:37   #10 (permalink)
ROBISH_GSM's Avatar
Member: 60523
Thanks Meter: 9
flashing N_GAGE ONLY AT prodigy so at griffen it make trying outpower fail
Old 07-19-2004, 18:40   #11 (permalink)
DMD
DMD's Avatar
Member: 12660
Thanks Meter: 7
@ Byte
PM is your permanent memory its like the eeprom on older phones that stores all the important data
Regards D.
Old 09-01-2010, 07:39   #12 (permalink)
Member: 783022
Thanks Meter: 14
Try this with flash file N-gage NEM-4
Try with this flah file with JAF/HWK
http://jeewanmobiles.nicetopic.net/nokia-f52/nokia-dct4-t78.htm
The Following User Says Thank You to kiran_g654 For This Useful Post:
how to flash e250i adda2004 Samsung Flashers, Software, Firmware. 0 03-29-2010 12:26
How To Flash N Gage S.SHANTHIKUMAR Griffin 3 04-22-2009 20:39
HOW TO FLASH N GAGE ADSP USING MTBox mitek MT-BOX 3 11-08-2005 14:51
how to flash n-gage rh-29 mas comm Twisterflasher 0 01-27-2005 12:40
how to flash N-GAGE with GriffinBox 2.08 MetalGie WD2 & APE (Symbian Phones) 0 03-23-2004 09:05
Page generated in 0.28503 seconds with 10 queries
