09-27-2008, 17:29 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 43
Member: 149032 Status: Offline Thanks Meter: 3,808 | ** How to make PM & RPL Backup and restore for BB5 or DCT4++ **Tutorial For JAF ** Click <INF > ----------- AF version 1.98.9 Detected PKEY: 9000***x Card life counter: 98.39% P-key nokia module version 01.00 Detected JAF INTERFACE version: 01.AC, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Setting test mode... Reading... MCU SW version: V 04wk47_m_v14 09-02-06 RM-36 (c) Nokia. HW version: 6001 PCI version: RFIC version: 150a160f DSP version: pb04w47v23 Retu version: 32 Tahvo version: 52 Production serial number: CQA650150 Product code: 0522047 Module code: Basic production code: 0516030 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 352278010710628 IMEI spare to net: 3A 25 72 08 01 17 60 02 IMEI SV to net: 33 25 72 08 01 17 60 22 F6 LOCK STATUS: CONFIG KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-36.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0522047 FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-36\RM36_4.050407_B5.C0R PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-36\RM36_4.050407_B5.v36 CNT Flash file: NONE APE Variant file: NONE Languages in ppm: Indian,Indonisia,Vietnamese Done! |
09-27-2008, 17:30 | #2 (permalink) |
Member: 149032 Status: Offline Thanks Meter: 3,808 | stap 2 *********How to backup bb5 NPC******** Way #1 (will display more info after) ----------------------- Untick: use INI tick: CRT 308 tick: CRT BKP DO NOT SELECT ANY MCU / PPM Now click FLASH FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Backing up CRT data... Setting FLASH MODE Loader version: 01.10.02 -> Revision: 0000 Patching CMT boot step2... CMT Boot Ready Loader version: 01.10.01 -> Revision: 0000 CMT Loader Ready Reading NPC certificate... Reading VARIANT certificate... VARIANT CRT empty, skip save... Reading CCC certificate... CCC not available... Reading HWC certificate... HWC not available... Saved to C:\Program Files\ODEON\JAF\ProgData\3522781710628_CRT_backup_ 47173.rpl Backup CRT OK! Backing up SIMLOCK data... Setting local mode... Reading IMEI... C:\Program Files\ODEON\JAF\ProgData\352278010710628_CRT_backu p_47173.pm Done! Backup LCK OK! Done! Total time: 0 Minutes, 0 Seconds DCT4/BB5 counter: 20 After flash processing... Waiting for phone to boot... Setting test mode... Reading... Phone type: RM-36, Software version: 04wk47_m_v14 IMEI: 352278010710628 APE Ver: V 5.04.07 15-02-06 RM-36 (c) NOKIA. Variant Ver: V 5.04.07-APAC2 15-02-06 RM-36 (c)NOKIA Product Code: 0522047 Done! |
The Following 2 Users Say Thank You to gopalhot For This Useful Post: |
09-27-2008, 17:32 | #3 (permalink) |
Member: 149032 Status: Offline Thanks Meter: 3,808 | stap 3 Way #2 ----------- Click CRT Tool > Backup CRT Setting FLASH MODE Loader version: 01.10.02 -> Revision: 0000 Patching CMT boot step2... CMT Boot Ready Loader version: 01.10.01 -> Revision: 0000 CMT Loader Ready Reading NPC certificate... Reading VARIANT certificate... VARIANT CRT empty, skip save... Reading CCC certificate... CCC not available... Reading HWC certificate... HWC not available... Saved to C:\Program Files\ODEON\JAF\ProgData\3522781710628_CRT_backup_ 410173.rpl Done! |
The Following User Says Thank You to gopalhot For This Useful Post: |
09-27-2008, 17:33 | #4 (permalink) |
Member: 149032 Status: Offline Thanks Meter: 3,808 | stap4 ********* End of backup bb5 NPC******** So, in any case if you got things like this on the phones that you already backed up....... This way how to restore it: Click <INF FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Setting test mode... Reading... MCU SW version: V 04wk47_m_v14 09-02-06 RM-36 (c) Nokia. PCI version: RFIC version: 150a160f DSP version: pb04w47v23 Retu version: 32 Tahvo version: 52 Production serial number: Product code: 0522048 Module code: Basic production code: Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 12345610654321? IMEI spare to net: 1A 32 54 16 60 45 23 01 IMEI SV to net: 13 32 54 16 60 45 23 21 F6 LOCK STATUS: CONFIG KEY: 2BE6807C969DC958 Provider: Unknown provider Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-36.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0522048 FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-36\RM36_4.050407_B5.C0R PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-36\RM36_4.050407_B5.v36 CNT Flash file: NONE APE Variant file: NONE Languages in ppm: Indian,Indonisia,Vietnamese Done! |
09-27-2008, 17:34 | #5 (permalink) |
Member: 149032 Status: Offline Thanks Meter: 3,808 | stap5 Now click CRT Tool ---------------------- 1. Operation: Write RPL , Tick Plain RPL 2. Select RPL (you saved it in your folder, remember?) ** in this case, located on C:\Program Files\ODEON\JAF\ProgData\3522781710628_CRT_backup_ 410173.rpl 3. Write RPL 4. Close Scanning RPL file... NPC DATA OK... VARIANT DATA NOT FOUND... CCC DATA NOT FOUND... HWC DATA NOT FOUND... SIMLOCK DATA NOT FOUND... SIMLOCK KEY DATA NOT FOUND... SUPERDONGLE KEY DATA NOT FOUND... CMLA KEY DATA NOT FOUND... WMDRM PD DATA NOT FOUND... Connecting to phone... Setting LOCAL MODE... CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg Loader version: 01.10.02 -> Revision: 0000 Patching CMT boot step2... CMT Boot Ready CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.10.01 -> Revision: 0000 CMT Loader Ready Writing NPC DATA... Restarting phone... Done! |
09-27-2008, 17:35 | #6 (permalink) |
Member: 149032 Status: Offline Thanks Meter: 3,808 | stap6 Now phone should be "Phone start up failed, Contact Retailer" ** You will need to restore your original CRT PM, in this case is located on C:\Program Files\ODEON\JAF\ProgData\352278010710628_CRT_backu p_47173.pm Next operation : Click Write PM > Service ----------------------------------- Powering the phone... Writing PM... Field: 308, Record: 1, Len: 4096 -> OK Done! |
09-27-2008, 17:36 | #7 (permalink) |
Member: 149032 Status: Offline Thanks Meter: 3,808 | stap7 Last Operation: write full pm. ------------------------------- You will need SX4 server for this operation. Tick SX4 AUTH > Service Checking for local SX card... Trying to use SX4 server... Server say: Hello! Login... Detected P-KEY: 9000***x Server say: Login OK, you are number 1 in the queue, you must wait aprox. 0 seconds... Connecting to phone... Done! |
09-27-2008, 17:37 | #8 (permalink) |
Member: 149032 Status: Offline Thanks Meter: 3,808 | And Then... > Tick Write PM > click Service Now select your good PM Powering the phone... Writing PM... Field: 1, Record: 0, Len: 114 -> OK Field: 1, Record: 1, Len: 4 -> OK Field: 1, Record: 2, Len: 86 -> OK Field: 1, Record: 4, Len: 110 -> OK Field: 1, Record: 5, Len: 4 -> OK Field: 1, Record: 6, Len: 86 -> OK Field: 1, Record: 8, Len: 110 -> OK Field: 1, Record: 13, Len: 86 -> OK Field: 1, Record: 15, Len: 4 -> OK Field: 1, Record: 16, Len: 86 -> OK Field: 1, Record: 18, Len: 86 -> OK Field: 1, Record: 20, Len: 86 -> OK Field: 1, Record: 22, Len: 16 -> OK Field: 1, Record: 23, Len: 4 -> OK Field: 1, Record: 24, Len: 84 -> OK Field: 1, Record: 25, Len: 16 -> OK Field: 1, Record: 29, Len: 6 -> OK Field: 2, Record: 0, Len: 340 -> OK Field: 4, Record: 0, Len: 1 -> OK Field: 4, Record: 1, Len: 16 -> OK Field: 4, Record: 2, Len: 44 -> OK Field: 4, Record: 3, Len: 10 -> OK Field: 4, Record: 4, Len: 8 -> OK Field: 4, Record: 5, Len: 8 -> OK Field: 4, Record: 9, Len: 5 -> OK Field: 8, Record: 0, Len: 12 -> OK Field: 8, Record: 1, Len: 12 -> OK Field: 8, Record: 6, Len: 4 -> OK Field: 8, Record: 7, Len: 8 -> OK Field: 11, Record: 0, Len: 4 -> OK Field: 11, Record: 1, Len: 4 -> OK Field: 11, Record: 2, Len: 4 -> OK Field: 11, Record: 3, Len: 4 -> OK Field: 11, Record: 4, Len: 1 -> OK Field: 11, Record: 5, Len: 6 -> OK Field: 11, Record: 6, Len: 1 -> OK Field: 11, Record: 7, Len: 2 -> OK Field: 11, Record: 8, Len: 2 -> OK Field: 11, Record: 9, Len: 2 -> OK Field: 11, Record: 10, Len: 2 -> OK Field: 11, Record: 11, Len: 2 -> OK Field: 11, Record: 12, Len: 1 -> OK Field: 11, Record: 13, Len: 1 -> OK Field: 11, Record: 14, Len: 1 -> OK Field: 11, Record: 15, Len: 1 -> OK Field: 11, Record: 16, Len: 1 -> OK Field: 11, Record: 17, Len: 1 -> OK Field: 11, Record: 18, Len: 1 -> OK Field: 11, Record: 19, Len: 2 -> OK Field: 11, Record: 20, Len: 2 -> OK Field: 11, Record: 21, Len: 1 -> OK Field: 11, Record: 22, Len: 1 -> OK Field: 11, Record: 23, Len: 4 -> OK Field: 11, Record: 24, Len: 4 -> OK Field: 11, Record: 25, Len: 2 -> OK Field: 11, Record: 26, Len: 2 -> OK Field: 11, Record: 27, Len: 2 -> OK Field: 11, Record: 28, Len: 2 -> OK Field: 11, Record: 29, Len: 1 -> OK Field: 11, Record: 30, Len: 1 -> OK Field: 11, Record: 31, Len: 1 -> OK Field: 11, Record: 32, Len: 1 -> OK Field: 11, Record: 33, Len: 1 -> OK Field: 11, Record: 34, Len: 1 -> OK Field: 11, Record: 35, Len: 1 -> OK Field: 11, Record: 36, Len: 1 -> OK Field: 11, Record: 37, Len: 1 -> OK Field: 11, Record: 38, Len: 2 -> OK Field: 11, Record: 39, Len: 2 -> OK Field: 11, Record: 40, Len: 2 -> OK Field: 11, Record: 41, Len: 2 -> OK Field: 11, Record: 42, Len: 2 -> OK Field: 11, Record: 43, Len: 4 -> OK Field: 11, Record: 44, Len: 4 -> OK Field: 11, Record: 45, Len: 4 -> OK Field: 11, Record: 46, Len: 1 -> OK Field: 11, Record: 47, Len: 16 -> OK Field: 11, Record: 48, Len: 2 -> OK Field: 11, Record: 49, Len: 2 -> OK Field: 11, Record: 50, Len: 20 -> OK Field: 11, Record: 51, Len: 10 -> OK Field: 11, Record: 52, Len: 2 -> OK Field: 11, Record: 53, Len: 20 -> OK Field: 11, Record: 54, Len: 10 -> OK Field: 11, Record: 55, Len: 1 -> OK Field: 11, Record: 56, Len: 1 -> OK Field: 11, Record: 57, Len: 1 -> OK Field: 11, Record: 58, Len: 1 -> OK Field: 11, Record: 59, Len: 1 -> OK Field: 11, Record: 60, Len: 1 -> OK Field: 11, Record: 61, Len: 1 -> OK Field: 11, Record: 62, Len: 1 -> OK Field: 11, Record: 63, Len: 1 -> OK Field: 11, Record: 64, Len: 1 -> OK Field: 11, Record: 65, Len: 1 -> OK Field: 11, Record: 66, Len: 2 -> OK Field: 11, Record: 67, Len: 2 -> OK Field: 11, Record: 68, Len: 2 -> OK Field: 11, Record: 69, Len: 2 -> OK Field: 11, Record: 70, Len: 2 -> OK Field: 11, Record: 71, Len: 2 -> OK Field: 11, Record: 72, Len: 2 -> OK Field: 11, Record: 73, Len: 2 -> OK Field: 11, Record: 74, Len: 2 -> OK Field: 11, Record: 75, Len: 2 -> OK Field: 11, Record: 76, Len: 2 -> OK Field: 11, Record: 77, Len: 2 -> OK Field: 11, Record: 78, Len: 2 -> OK Field: 11, Record: 79, Len: 2 -> OK Field: 11, Record: 80, Len: 2 -> OK Field: 11, Record: 81, Len: 2 -> OK Field: 11, Record: 82, Len: 2 -> OK Field: 11, Record: 83, Len: 2 -> OK Field: 11, Record: 84, Len: 2 -> OK Field: 11, Record: 85, Len: 2 -> OK Field: 11, Record: 86, Len: 2 -> OK Field: 11, Record: 87, Len: 2 -> OK Field: 11, Record: 88, Len: 2 -> OK Field: 11, Record: 89, Len: 2 -> OK Field: 11, Record: 90, Len: 2 -> OK Field: 11, Record: 91, Len: 2 -> OK Field: 11, Record: 92, Len: 2 -> OK Field: 11, Record: 93, Len: 2 -> OK Field: 11, Record: 94, Len: 2 -> OK Field: 11, Record: 95, Len: 2 -> OK Field: 11, Record: 96, Len: 2 -> OK Field: 11, Record: 97, Len: 2 -> OK Field: 11, Record: 98, Len: 2 -> OK Field: 11, Record: 99, Len: 2 -> OK Field: 11, Record: 100, Len: 2 -> OK Field: 11, Record: 101, Len: 2 -> OK Field: 11, Record: 102, Len: 2 -> OK Field: 11, Record: 103, Len: 2 -> OK Field: 11, Record: 104, Len: 2 -> OK Field: 11, Record: 105, Len: 2 -> OK Field: 11, Record: 106, Len: 2 -> OK Field: 11, Record: 107, Len: 2 -> OK Field: 11, Record: 108, Len: 4 -> OK Field: 11, Record: 109, Len: 4 -> OK Field: 11, Record: 110, Len: 1 -> OK Field: 11, Record: 111, Len: 4 -> OK Field: 11, Record: 112, Len: 4 -> OK Field: 11, Record: 113, Len: 4 -> OK Field: 11, Record: 114, Len: 4 -> OK Field: 11, Record: 115, Len: 16 -> OK Field: 11, Record: 116, Len: 4 -> OK Field: 11, Record: 117, Len: 2 -> OK Field: 11, Record: 118, Len: 2 -> OK Field: 11, Record: 119, Len: 857 -> OK Field: 17, Record: 0, Len: 4 -> OK Field: 25, Record: 0, Len: 64 -> OK Field: 26, Record: 0, Len: 16 -> OK Field: 26, Record: 1, Len: 32 -> OK Field: 26, Record: 2, Len: 68 -> OK Field: 26, Record: 3, Len: 6 -> OK Field: 27, Record: 0, Len: 15 -> OK Field: 29, Record: 0, Len: 6 -> OK Field: 35, Record: 0, Len: 10 -> OK Field: 43, Record: 5, Len: 4 -> OK Field: 44, Record: 0, Len: 1 -> OK Field: 50, Record: 0, Len: 2 -> OK Field: 54, Record: 0, Len: 2 -> OK Field: 88, Record: 0, Len: 36 -> OK Field: 94, Record: 0, Len: 40 -> OK Field: 95, Record: 0, Len: 1 -> OK Field: 95, Record: 1, Len: 1 -> OK Field: 96, Record: 0, Len: 24 -> OK Field: 117, Record: 0, Len: 4 -> OK Field: 117, Record: 1, Len: 3 -> OK Field: 117, Record: 2, Len: 6 -> OK Field: 117, Record: 3, Len: 1 -> OK Field: 117, Record: 4, Len: 9 -> OK Field: 117, Record: 5, Len: 10 -> OK Field: 117, Record: 6, Len: 8 -> OK Field: 117, Record: 13, Len: 3 -> OK Field: 117, Record: 14, Len: 3 -> OK Field: 118, Record: 0, Len: 1 -> OK Field: 193, Record: 2, Len: 8 -> OK Field: 193, Record: 3, Len: 32 -> OK Field: 193, Record: 4, Len: 32 -> OK Field: 193, Record: 7, Len: 1 -> OK Field: 217, Record: 0, Len: 32 -> OK Field: 239, Record: 0, Len: 2 -> OK Field: 239, Record: 1, Len: 1753 -> OK Field: 239, Record: 2, Len: 1753 -> OK Field: 239, Record: 3, Len: 1753 -> OK Field: 248, Record: 0, Len: 120 -> OK Field: 307, Record: 0, Len: 1 -> OK Field: 308, Record: 0, Len: 1 -> OK Field: 308, Record: 1, Len: 4096 -> OK Field: 308, Record: 2, Len: 1 -> OK Field: 308, Record: 3, Len: 1 -> OK Field: 308, Record: 4, Len: 1 -> OK Field: 309, Record: 0, Len: 4 -> OK Field: 309, Record: 1, Len: 2 -> OK Field: 309, Record: 2, Len: 12 -> OK Field: 309, Record: 4, Len: 12 -> OK Field: 309, Record: 5, Len: 12 -> OK Field: 309, Record: 7, Len: 12 -> OK Field: 309, Record: 8, Len: 12 -> OK Field: 309, Record: 17, Len: 12 -> OK Done! |
09-27-2008, 17:38 | #9 (permalink) |
Member: 149032 Status: Offline Thanks Meter: 3,808 | Ensure your self : Click INF FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Setting test mode... Reading... MCU SW version: V 04wk47_m_v14 09-02-06 RM-36 (c) Nokia. HW version: 6001 PCI version: RFIC version: 150a160f DSP version: pb04w47v23 Retu version: 32 Tahvo version: 52 Production serial number: CQA650150 Product code: 0522047 Module code: Basic production code: 0516030 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 352278010710628 IMEI spare to net: 3A 25 72 08 01 17 60 02 IMEI SV to net: 33 25 72 08 01 17 60 22 F6 LOCK STATUS: CONFIG KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-36.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0522047 FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-36\RM36_4.050407_B5.C0R PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-36\RM36_4.050407_B5.v36 CNT Flash file: NONE APE Variant file: NONE Languages in ppm: Indian,Indonisia,Vietnamese Done! |
The Following 4 Users Say Thank You to gopalhot For This Useful Post: |
** How to make PM & RPL Backup and restore for BB5 or DCT4++ **Tutorial For JAF ** | R@ZIB-BD | Nokia Base Band 5 ( BB-5 ) | 0 | 09-15-2009 12:37 |
How to make iPhone Ringtones on Mac and Windows for FREE | lutospascal | Off Topic Zone | 0 | 05-26-2009 08:18 |
Tutorial **How to make PM & RPL Backup and restore for BB5 or DCT4++ ** | digiphone | Nokia Base Band 5 ( BB-5 ) | 21 | 05-16-2009 05:13 |
How to make PM & RPL Backup and restore for BB5 or DCT4++ **Tutorial For JAF** | Read Alart | Off Topic Zone | 1 | 04-09-2009 20:29 |
how to make a ic2 bus cable and how to use? | alro | Hardware Repair by brands | 4 | 06-20-2001 11:22 |
