Old 04-19-2004, 03:05   #1 (permalink)
Member: 12207
Thanks Meter: 2
Re-using UEM??
Hi.
I have one nok 7650 wich has a uem with a good imei! now, i want to change this uem to a nokia 8310! can i change it, and will the 8310 work?
Oh, 7650 is pretty dead, so it's helpless to read flash imei data from it!
Thanks in advance
Regards
XARiUS
Old 04-19-2004, 03:27   #2 (permalink)
ulo
Member: 13987
Sonork: None
Thanks Meter: 2
Originally Posted by XARiUS
Hi.
Thanks in advance
Regards
XARiUS
It won't work UEM is one time programming only, better use a brand new UEM
Old 04-19-2004, 14:20   #3 (permalink)
The Racer's Avatar
Member: 20490
Thanks Meter: 3
I think it work but i dont have time to do it right now. I'll test it soon. You'll have 7650 imei after this( no problem?)
Old 04-19-2004, 14:29   #4 (permalink)
evilspell's Avatar
Member: 4160
we also tried but it's not possible.
br
Old 04-19-2004, 14:33   #5 (permalink)
The Racer's Avatar
Member: 20490
Thanks Meter: 3
using from another dead 8310 to the damaged imei 8310 is not possible?!
i think 7650 uem is different from 8310 uem anyway i'll post soon my results.
Old 04-19-2004, 18:30   #6 (permalink)
Member: 39601
Thanks Meter: 13
All the UEMs are the same ,they worksfor each phones. dont use an exess heat , install the ( known IMEI ) UEM in the new phone , make an ASK file , requset an RPL on that ASK file , and finaly upload it. As U see it is the usuall routein , but now it works
Old 04-19-2004, 20:27   #7 (permalink)
Member: 1060
Thanks Meter: 10
for the 8310 .. if you use "total" new UEM, then any OLD ( type 2 ) RPL will work !
for you like to remove UEM 7650 and install to 8310, it will work-----> if you can make rpl by your own ! ( but not good ) becasue your 8310 will have same IMEI to 7650 , it mean, you have to have know 7650 original IMEI
Regard
Old 04-19-2004, 23:50   #8 (permalink)
Member: 45635
Thanks Meter: 20
i think that it will power on . but the problem is how to face PHONE RESTRECTED ....you cannot write original imei to the old one ........
Old 04-20-2004, 00:12   #9 (permalink)
Member: 7062
Thanks Meter: 126
Regard
just 2 inquiries
did the data 1 same in type 2 and type 5 wd2 series??
did this not affect the msid to inhance the network data correctly ???
Old 04-20-2004, 03:38   #10 (permalink)
Member: 1060
Thanks Meter: 10
for the "SER_PROG_DATA_OUT"
DATA1 --> write to flash rom
DATA2 -->write to UEM
Old 04-20-2004, 05:03   #11 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
You just need Griffin team account for Flash IMEI rebuild (or friend with account for you, or similar service from someone...) . Place good working (and not empty!) UEM (from your 7650 for example) in your N8310. Readout ask file (this file will containt already programed in UEM IMEI - in your case - from 7650) - Griffin server will recalculate for you Flash UEM rebuild *.rpl file - upload this file to phone - enjoy!
Old 04-20-2004, 05:58   #12 (permalink)
Member: 12207
Thanks Meter: 2
Hi! First, thanks to all for your help! It really helped me a lot!
Oh, to the guys who missunderstood my question... The 7650 is completely dead! So it won't be 2 phones with the same IMEI because 7650 will not functioning again! That's why i wanna get the UEM and re-use it! Too bad i can't read 7650 IMEI data from flash, because a took it off, and i'm not able to reballing it!
Again... Thanks to alll...
Regards
XARiUS
Old 01-02-2005, 19:01   #13 (permalink)
Member: 65714
Thanks Meter: 17
some times it work, but no longer life
i done this before
Old 01-07-2005, 13:53   #14 (permalink)
Member: 58665
you can not do this
uem is just for one phone and when it write once you cant rewrite it
so you cant use uem of one phone for another however they are same phone
its not possible my friend
and i think its better to buy a new uem and write it with griffin or ufs
good luck
Old 06-14-2005, 08:23   #15 (permalink)
yoya's Avatar
Member: 80255
Thanks Meter: 15
It is posibile but you must wrote same rpl to uem like wroten first time, i tested, change same uem in 3100, 6610, 3200, every time wrote same rpl and phone working good, that can use to test anodher function of phone if everything ok put him new uem.
BEST REGARDS
re-using sim cards fofodaman Sim Cloning and Scaning 17 10-06-2013 10:07
after SD calculation, then there is a backup file,can re used it again ? mantok Universalbox 20 12-22-2009 11:49
re use old box - how to get support fordgt40 HWK 6 03-27-2008 09:20
trouble flashing used-uem n flash ufs_ternoda Nokia Digital Core Technology 4 ( DCT-4 ) 0 12-02-2007 03:11
Page generated in 0.26028 seconds with 9 queries
