07-26-2007, 15:05 | #1 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 217853 Status: Offline Thanks Meter: 13 | How To Refix 6260 Battery Connecter I M Waiting |
07-26-2007, 16:09 | #6 (permalink) |
No Life Poster Join Date: Jan 2006 Location: EGYPT Age: 47
Member: 217479 Status: Offline Thanks Meter: 267 | I know it will not be so helpful but the best way to replace such connectors using Infra rework stations, if you got a friend have one it will be so helpful & so easy, G.O.D assist ... |
07-26-2007, 16:17 | #7 (permalink) | |
Member: 217853 Status: Offline Thanks Meter: 13 | Quote:
i don't have infra red .then what the next option remains .just iron only .i tried very hard but fail to fix .did u ever change it before .if not ,if same problem comes to u what step do u take . | |
07-26-2007, 16:31 | #8 (permalink) |
Member: 217479 Status: Offline Thanks Meter: 267 | About me, thanks G.O.D i have Infra-station; so if same problem comes to me i will use it. About second solution; since the battery connector is unsolderd then i will face its side to down then to reflow from under till desolder and pick up the on-board flex connector & the keypad connector, turn the board upside down then to place the new battery connector properly & reflow from under to solder it, at last to solder the two unsoldered connectors back again with solder iron. Imp note: If you gonna try it, you must first remove the label sticker. Hope it's more helpful ... |
04-15-2008, 17:51 | #9 (permalink) |
Junior Member Join Date: Apr 2008
Member: 749993 Status: Offline Sonork: 111866 Thanks Meter: 1 | Hi I have a nokia 6260 and I got it all right but when I put my battery and try to on the phone the phone does not respond but after pressing the battery from the back it turns on without on off switch function, but all of a sudden the phone again turns off has to repeat the same thing pls. help me to get rid from this problem I shall be highly oblidged. |
need video how to dismantle 6260 | bugztronic | Nokia Hardware & Hardware Repair | 1 | 10-04-2006 19:20 |
how to flash 6260 with Twistier/UFS? | dipu | WD2 & APE (Symbian Phones) | 1 | 05-15-2006 08:09 |
How to open 6260 | Yoda_Brno | Nokia Hardware & Hardware Repair | 8 | 05-02-2005 22:30 |
How to unlock 6260???... | piscancek | WD2 & APE (Symbian Phones) | 0 | 11-03-2004 09:15 |
