Old 12-08-2008, 10:17   #1 (permalink)
Member: 411831
Thanks Meter: 215
how to remove contact retailer from n72?
i have a n72 contact retailer.
i try to format by mt-box,hwk,jaf etc.
also write good pm to use shx.
but problem is presist
need help.
Old 12-08-2008, 10:46   #2 (permalink)
Binoy.c's Avatar
Member: 523496
Sonork: ammachis
Thanks Meter: 76
try manualformatting reball or change comboflash goodluck
The Following User Says Thank You to Binoy.c For This Useful Post:
Old 12-08-2008, 10:52   #3 (permalink)
jabed_net's Avatar
Member: 538824
Thanks Meter: 274
Bro pls post your log here .
The Following User Says Thank You to jabed_net For This Useful Post:
Old 12-08-2008, 10:59   #4 (permalink)
Parminder Singh's Avatar
Member: 476739
Thanks Meter: 507
fist clean bord and normal heat then
flash same verson with mcu or ppm file
The Following User Says Thank You to Parminder Singh For This Useful Post:
Old 12-08-2008, 11:34   #5 (permalink)
Member: 917289
Sonork: "ergo proxy"
Thanks Meter: 6
try manual format.......
The Following User Says Thank You to madarame™ For This Useful Post:
Old 12-08-2008, 14:26   #6 (permalink)
iqballk's Avatar
Member: 13932
Sonork: 100.1609876
Thanks Meter: 410
search contact retailer guide posted by me..
regards..
The Following User Says Thank You to iqballk For This Useful Post:
Old 12-08-2008, 14:58   #7 (permalink)
Member: 350629
Thanks Meter: 18
fist clean bord and normal heat then try manual formate
The Following User Says Thank You to sweethoney_1714 For This Useful Post:
Old 12-08-2008, 15:18   #8 (permalink)
Member: 265606
Sonork: 1603113
Thanks Meter: 460
first u do manual format by pressing * + 3 + calling button + on/off key
The Following User Says Thank You to yusufali786 For This Useful Post:
Old 12-08-2008, 17:28   #9 (permalink)
Member: 411831
Thanks Meter: 215
@all thanks
very much.
Old 12-08-2008, 17:37   #10 (permalink)
Member: 132523
Thanks Meter: 10
try to factory seting with jaf first
Old 07-14-2009, 09:17   #11 (permalink)
Member: 588930
Thanks Meter: 16
hallo team i need solution for n72.70 phone contact retailer i have same contion more mobiles plsssssssssss
Old 07-14-2009, 09:35   #12 (permalink)
s.s.s.s.'s Avatar
Member: 988641
Sonork: sanjay chaudhary
Thanks Meter: 342
bro,
try to change boot ic and jocus.................
Old 07-14-2009, 11:07   #13 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
First full erease u r phone thane flash phone update file thane sx4 & write good or buckup pm thane unlock with zulia ur problem
solve 100%.If not thane u replace flasher ic.
Old 10-08-2009, 14:17   #14 (permalink)
Member: 617031
Thanks Meter: 45
brother first write pm then check flash ic
NHL-12 6620 how to solve Contact Retail ???????? mr_rocco MT-BOX 16 12-27-2009 11:28
How to remove Contact Retailer? oqaab J.A.F. By Jafsupport.com 9 07-05-2008 22:17
..::another Trick To Remove Contact Service FROM Nokia 1112 ::.. HUM Nokia Hardware & Hardware Repair 41 05-19-2008 10:33
HOW to remove CONTACT RETAILER "BB5" S E N O P A T I MT-BOX 1 05-10-2007 15:44
Page generated in 0.18769 seconds with 9 queries
