06-18-2002, 01:58 | #1 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Omsk, Russia Age: 41
Member: 7337 Status: Offline Thanks Meter: 0 | How to remove glue around BGA ICs on Nokia? How to remove it without damaging the IC? |
06-18-2002, 07:46 | #2 (permalink) |
Freak Poster Join Date: May 2002 Location: Perth, Western Australia Age: 45
Member: 11937 Status: Offline Thanks Meter: 1 | Unfortunetly i dont know of any good way to do this. With heat you can, but the amount of heat required to make the epoxy glass-like and fragile enough to splinter would destroy the rest of the pcb. Chemically ive heard rumours of concentrated sulphuric acid been able to remove the epoxy, but i havent tried it and i dont intend to!! That epoxy is a piece of ****, ive got a 8850 with a faulty MAD2 DSP which is underfilled. |
06-18-2002, 07:58 | #3 (permalink) |
No Life Poster Join Date: Jul 2001 Location: md Age: 25
Member: 5379 Status: Offline Thanks Meter: 0 | i've heard some info about this later. Some friend of mine said that mercury could melted down the epoxy under bga ic's, but i never tried this and i should warned first, mercury is a very toxic and dangerous substance, it could evaporate easily and if inhaled could very dangerous to our health. So try this at your own risk Good luck |
07-15-2002, 04:35 | #4 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Radiometer Medical ApSBrønshøj Age: 51
Member: 10854 Status: Offline Sonork: 1578988 Thanks Meter: 3 | Hiya Put some flux over the chip and heat it from other side of board ( thru board )...It might help... BUT!!!!!!!! Try this only if phone is already dead....U have nothing to loose... BR Vule |
07-15-2002, 16:26 | #5 (permalink) |
Freak Poster Join Date: Aug 2001 Location: GSMLAND
Member: 5764 Status: Offline Thanks Meter: 2 | take some needle and insert it through glue underneath BGA. Heat it with airgun from all the sides and slightly move the needle upside. after removing BGA, clean the glue with pincette and airgun. |
07-16-2002, 23:47 | #6 (permalink) |
Freak Poster Join Date: Oct 2001 Location: Malaysia
Member: 6963 Status: Offline Thanks Meter: 1 | Yes, Sat This is the common way to removed BGA IC with epoxy glue in China. I noticed most of H/P repair man can handle very well during my last month visited China. Just remove with Hot air ****er with out apply any glue removing chemical. Is need some skill to do this and you may need to practice more........ Regards |
07-17-2002, 00:59 | #7 (permalink) |
No Life Poster Join Date: Jul 2001 Location: RP Age: 48
Member: 5246 Status: Offline Thanks Meter: 9 | Yes, agree. But no amount of practice will assure you that no tracks will be removed from the board 100% It's always a 50-50 deal regarding underfilled BGA ICs. Tip is that your should ensure that the IC is heated on all sides. |
07-17-2002, 01:54 | #8 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Viet Nam Age: 49
Member: 5487 Status: Offline Thanks Meter: 5 | Hi I do it alots , only use hot air and blade to remove it. But only depend on your skill.You must practic more. I do it all day. Almost nokia 8250 hold is wrong in MCU so you must take it and re sold MCU. May be IC will die but the board never damage because Nokia board verry good. Don't try it with Samsung fone you will kill it.PCB of samsung fone not good and glue verry strong than glue on nokia fone. Best regards |
07-17-2002, 21:06 | #10 (permalink) |
Member: 5487 Status: Offline Thanks Meter: 5 | Hi about 200 degree and air strong . If use 850 chose hot = 5 and air = 5 but it is your experience. And dependence of your hot air. You must test it. And have your experience I think I can't only talk it... But not verry hot only the same when you use to sold or desold BGA. best regards. |
07-18-2002, 04:21 | #11 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Earth
Member: 7934 Status: Offline Thanks Meter: 0 | Hi all, It's a dangerous operation to do. You can work for many hours and you will sucess only for few times. So change the BGA with glue arround only if your customer acept the risk to have a damaged phone. but some times good luck is here Regards |
07-18-2002, 18:47 | #12 (permalink) |
Member: 5764 Status: Offline Thanks Meter: 2 | yes, customer should be warned first. sometimes PCB legs are torn. then you have nothing to do. but mostly on Nokia's, about 90 %, changing processor is possible. |
07-21-2002, 19:59 | #13 (permalink) |
Insane Poster Join Date: Mar 2002 Location: Computer Hospital Age: 47
Member: 9828 Status: Offline Thanks Meter: 2 | quang thao; i'm using digital hi-temp thermometer 5mm away from hot air's nozzle with the temp. of 200 degree celsius. and heated to glued bga but not succes on melting the balls . i think 200 deg. is not enough and how do you measure ur 850 hot air temp. p.s. i think the epoxy that used in the bga is the same as the one using for encapsulant for encapsulated smd ic as you have seen on some of the electronic watches. there's a remover for that epoxy some of my freinds told me, i try to recall that name of the solution maybe i'll post it tomorrow. |
How To Remove Glue From K610 Glue Pasted Chips | sairat | DreamBox | 3 | 04-20-2008 16:57 |
how to remove glue on N80 /7390 | MORRISGSM | MT-BOX | 5 | 09-20-2007 20:48 |
How to remove glue arround components? | Futuro | Nokia Hardware & Hardware Repair | 1 | 01-05-2005 15:52 |
how to remove glue under mutimodule on T68 | SE-THAILAND | Sony Ericsson Hardware Repair | 10 | 04-04-2003 04:48 |
How to remove glue under Ccont in 8210? | Trier | Nokia Hardware & Hardware Repair | 12 | 11-02-2002 01:20 |
