Old 01-10-2010, 18:49   #1 (permalink)
Member: 1102317
Thanks Meter: 180
Thumbs up How to Repair a Dead Mobile Phone
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting does'nt go it may be due to shorting in an ic,capaicitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic bacomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU
The Following 4 Users Say Thank You to akram855 For This Useful Post:
Old 01-10-2010, 22:19   #2 (permalink)
chohansahib's Avatar
Member: 719944
Thanks Meter: 2,117
thanxxxxxx for info for new engineers .........
Old 01-11-2010, 03:28   #3 (permalink)
chetanmaturkar7's Avatar
Member: 986394
Thanks Meter: 168
very very nice solution.keep it up............................................
Old 01-11-2010, 13:16   #4 (permalink)
Member: 891893
Thanks Meter: 24
Arrow Congratulation
1. Water damage
2. Fall down
Many many thanks for the post
How to Repair a Dead Mobile Phone akram855 Various CDMA/TDMA Cell Phones 21 08-16-2016 12:01
@@@...How To Repair A Dead China Phone by [email protected]@@ mobi_soft Chinese Models & Cloned Phones 7 07-21-2014 08:51
How to repair liquid damage mobile phones?? Slick123 Nokia Hardware & Hardware Repair 44 10-01-2007 08:49
How To Repair A Dead Siemens Phone By Using Dreambox?? Eagle7 DreamBox 1 07-21-2006 15:58
GRiffin / GTS BOX How to repair a DEAD PHONE ? mail_man Griffin 4 03-25-2006 12:46
Page generated in 0.28344 seconds with 8 queries
