Old 06-16-2006, 19:58   #1 (permalink)
Member: 260672
Thanks Meter: 20
>>How to Repair Dead Nokia 2600<<
Hi Guys,
I am trying to flash a dead nokia 2600 with N-Box....i am having trouble flashing it...i am providing the log from N-Box
1st Boot Ok, DCT4, UPP: 1201
Fl0: 0x01000000-0x01FFFFFF,19E4FA3B,
Algorithm: u_intel.fia, Ver: 4.19.0
Algorithm Ok, MSID: 84218202BA3D7E3FB6AB3842F1
Decoded MSID: 3E4EBAE9-00D3B37C-A9000000
Encoded FAID: 8EEFB07B-B03B8471-F793ACCA
Erasing: 0x01000000-0x0100FFFF ...
Erasing Error: 10, at: 0x01000000-0x0100FFFF, 940207, Time: 00:00
Process Failed, Repowering Mobile
can anyone give me a solution to repair this phone
thanx in advance
Old 06-16-2006, 20:31   #2 (permalink)
Member: 171593
Thanks Meter: 13
May be if u continue trying it, hold the set tight, no hand checking, it will flash ok,
Also klick check, after klick flash immediatly.
Old 06-20-2006, 17:36   #3 (permalink)
Member: 260672
Thanks Meter: 20
Its didnt work do u have any more ideas
Old 06-20-2006, 21:22   #4 (permalink)
Member: 70830
try to heat the panel before flashing pls post result
Old 06-20-2006, 23:42   #5 (permalink)
Registered User
Member: 143939
Thanks Meter: 264
Try to rehot flash IC
Old 06-21-2006, 23:45   #6 (permalink)
Member: 142572
Thanks Meter: 2
Originally Posted by thoyyu
Hi Guys,
thanx in advance
apply heat with rework station on the flash ic. make sure u dont use soldering paste coz the ic could bend one side.then flash again. or run set up again
Old 06-27-2006, 03:26   #7 (permalink)
Member: 300907
Thanks Meter: 2
2600 Erashing Error Solution.
Hi,
I am trying to flash a dead nokia 2600 with ufs Box.
Select 2600 --> Erase --> Start Address 01000000 (Default) --> Change the End Address 01FFFFFF to 013FFFFF. Now erase the flash area.
Then write MCU and PPM files. Now Phone OK. (GSM 900 Mhz Signal Error).
Write 1100 PM File 34% only (Do not write full pm file). Remove the tick (Un Select) in Autodetect Product. Select 1100 --> Wr PM --> 1100 pm file --> Stop in 34% . Now phone work with 100% Good Signal.
Use same Method for 3100 & 3120. Thanks.
The Following 2 Users Say Thank You to Jageer For This Useful Post:
Old 06-27-2006, 07:03   #8 (permalink)
Member: 77254
Thanks Meter: 9
check the crystal 32.768khz...
Old 06-28-2006, 06:27   #9 (permalink)
Member: 301810
pls i want to repair nokia 2650, kindly help with its shematics diagram
Old 06-28-2006, 06:45   #10 (permalink)
.::Skylinks::.'s Avatar
Member: 300354
Sonork: 100.1577485
Thanks Meter: 760
Erase your 2600 using 1100 erase file.....Hope it works
Old 06-28-2006, 09:48   #11 (permalink)
Member: 16830
Thanks Meter: 32
Hi Guys,
thanx in advance
i had the same problem. i tryed to rehot the flash is, but dont` work. i changed the upp ic, and now it`s work fine. try it
Old 06-28-2006, 11:32   #12 (permalink)
rajiv007's Avatar
Member: 78767
Sonork: 100.95137
Thanks Meter: 566
i think its a flash IC problem try to use normal heat to flash IC then check
Old 06-30-2006, 01:35   #13 (permalink)
.:AnOuaR:.'s Avatar
Member: 62602
Thanks Meter: 6
Fl0: 0x01000000-0x01FFFFFF,87CDB60A,
Algorithm: u_intel.fia, Ver: 4.44.1
Algorithm Ok, MSID: 84A581166551D78216923EB542
Decoded MSID: 3E4EBAE9-005578A7-A8000000
Encoded FAID: 29C3B644-407D871C-6853E855
Erasing: 0x011FC000-0x011FFFFF ...
Erasing Error: 10, at: 0x011FC000-0x011FFFFF, 940207, Time: 00:00
same problem in 2600 are there solution ???
Old 08-17-2006, 15:13   #14 (permalink)
Member: 260672
Thanks Meter: 20
Originally Posted by Jageer View Post
Hi,
Hi,
I tried ur method but i cudnt flash the MCU & PPM it give me the same error message...i did erase using the addresses u provided me .
can u tell me how i can flash it
thanx in advance
Old 08-17-2006, 22:22   #15 (permalink)
sunsco's Avatar
Member: 216438
Sonork: 160962
Thanks Meter: 30
Thank Uuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu For This.
How To Repair Dead Nokia 1100 celluniversal Nokia Digital Core Technology 4 ( DCT-4 ) 10 11-26-2012 16:09
how to repair dead nokia n70 shakil143 Nokia Hardware & Hardware Repair 2 10-24-2009 02:27
how to repair dead nokia 1650 patelfaizu Nokia Hardware & Hardware Repair 2 07-15-2009 20:28
How To Repair Dead Nokia 1100 celluniversal Nokia Digital Core Technology 4 ( DCT-4 ) 5 09-25-2007 14:32
>>How to flash dead nokia 7610 with n-box<< thoyyu n-Box 3 06-22-2006 22:52
Page generated in 0.39190 seconds with 8 queries
