Old 10-06-2004, 04:23   #1 (permalink)
Member: 84278
Thanks Meter: 22
how to repair gsm units infected with caribe.sys virus?
Hey can anybody suggest what to do to remove virus caribe.sys that infects gsm cellphones with bluetooth connectivity? My phone is infected with the virus.
Old 10-06-2004, 06:31   #2 (permalink)
Member: 1060
Thanks Meter: 9
full factory reset
user area format !
Old 10-06-2004, 06:37   #3 (permalink)
pazeth™'s Avatar
Member: 74519
Thanks Meter: 60
press *#7370#
warning! your will lost your data
Old 10-06-2004, 06:47   #4 (permalink)
yousha's Avatar
Member: 17689
Sonork: 100.72392
Thanks Meter: 734
u can do it without loosing ur data
Old 10-06-2004, 07:03   #5 (permalink)
pazeth™'s Avatar
Member: 74519
Thanks Meter: 60
how??
tell me how to kick out virus without loasing data ???
Old 10-06-2004, 07:07   #6 (permalink)
Member: 51453
Thanks Meter: 729
give me your email i will send it to you without losing your data from the phone
Old 10-06-2004, 07:22   #7 (permalink)
a4tech's Avatar
Member: 26377
To remove SymbOS.Cabir:
1.Install a file manager program on the phone.
2.Enable the option to view the files in the system directory.
3.Search the drives, A through Y, for the \SYSTEM\APPS\CARIBE directory.
4.Delete the files CARIBE.APP, CARIBE.RSC, and FLO.MDL from the \CARIB directory.
5.Go to the C:\SYSTEM\SYMBIANSECUREDATA\CARIBESECURITYMANAGER directory.
6.Delete the files CARIBE.APP, CARIBE.RSC, and CARIBE.SIS.
7.Go to the C:\SYSTEM\RECOGS directory.
8.Delete the file, FLO.MDL.
9.Go to the C:\SYSTEM\INSTALLS directory.
10.Delete the file, CARIBE.SIS.
Note: You cannot delete the file CARIBE.RSC when the program is running. To kill app, smart launcher should be installed or other apps similar to it
If you cannot delete this file in steps 4 and 6, delete all the files that you can, restart the phone, and then delete the CARIBE.RSC file.
or
check here
Old 10-06-2004, 07:47   #8 (permalink)
yousha's Avatar
Member: 17689
Sonork: 100.72392
Thanks Meter: 734
@a4tech
Smart GUY good work :-)
Old 10-06-2004, 10:18   #9 (permalink)
pazeth™'s Avatar
Member: 74519
Thanks Meter: 60
bealive or not, virus can be infected other file and never stop..
Old 10-06-2004, 10:19   #10 (permalink)
pazeth™'s Avatar
Member: 74519
Thanks Meter: 60
it can copy it self to other folder
Old 11-03-2004, 09:47   #11 (permalink)
ocean0's Avatar
Member: 79152
Thanks Meter: 9
i have two phones ( nokia qd & 3660 )already infected!! the lcd have changed the pattern to some dots at screen show.... i try to used griffin & tornado to solve it.. but cannot. doest any 1 have any idea with this???? i try upgrade sorfware & full fromat to the phone and it still cannot work!!!! help me guy!!!
Old 11-03-2004, 10:18   #12 (permalink)
a4tech's Avatar
Member: 26377
i think its not software problem...
Old 11-03-2004, 12:08   #13 (permalink)
dannyogolo's Avatar
Member: 18200
Sonork: 100.1608286
Thanks Meter: 82
Correct Talk
The virus copies itself to many hidden directories.
Also after trying on about 9 different phones, I concluded that you cannot send any app to the infected phone thru Bluetooth. It overloads the Rx of the phone, simply bombarding the Tx. Your bluetooth enabled PC will only detect the phone IP (not the phone name as saved on it) like 45 D4 8Y 9I 67 F6R. This way you cannot send anything to the phone thru Bluetooth.
Old 11-03-2004, 17:18   #14 (permalink)
Member: 16430
Thanks Meter: 2
Use this app to remove,instruction inside.
Old 11-26-2004, 21:35   #15 (permalink)
chinex14's Avatar
Member: 30405
Thanks Meter: 3
Exclamation
Has there been any other solution apart from *#7370# I have a 3650 after typin that code i got a screen any time i power on the phone and I have flashed with griffin like 20times and always get Full factory set fail. Now is "Phone start up fail contact retailer"
can someone tell me what next to do
Cheers!!!!
How to repair 5130 contact service with fps-10 with sx4 smartcard...! swechacnu Nokia Base Band 5 ( BB-5 ) 11 12-28-2012 19:26
How To Repair Dead Units By Wrong Unlock Don martin Nokia Hardware & Hardware Repair 2 08-25-2008 23:36
How to repair Sagem 922 S7 with PB EEPROM 3? bimas Infineon C16X M51 & ARM7 M52 BASED 0 02-15-2002 23:57
How to repair 3210 v5.10 with dead eeprom? MaRiN Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 03-09-2001 09:31
How to repair A2618, after unlocking with zuelas unlocker? Enter Old Ericsson Phones & Sony Phones 5 01-02-2001 10:15
Page generated in 0.48198 seconds with 9 queries
