View Poll Results: Best new mobile phone | |||
nokia n80 | 12 | 21.82% | |
nokia 8800 black(gold chrome) | 10 | 18.18% | |
nokia n91 | 11 | 20.00% | |
sony w810 | 14 | 25.45% | |
samsung i300 | 1 | 1.82% | |
Other | 7 | 12.73% | |
Voters: 55. You may not vote on this poll |
11-17-2006, 13:27 | #18 (permalink) |
Freak Poster Join Date: Oct 2005 Location: perth aust.
Member: 188959 Status: Offline Thanks Meter: 7 | mate- i repair about 2000 fluid damaged phones a year, and MobilerepairLog is absolutely correct.DO NOT use solvents or petrol on PCB's, as it will break the board down.Methylated spirits will do ok if you haven't got ultrasonic cleaning fluid.Isopropyl alcohol does the trick too.Ignore those who say the phone will break down in a month.Sugar based ingression rarely fails after repair, especially if remnants are cleaned efficiently the first time.My job and good company name relies on phones not failing after repair, so i make sure the job is done PROPERLY, clean pcb well, and you will have no probs.If the battery is shorted [0.0v] , hit it with a power supply, or with about 5v for a short time on the battery, then put on charge, should bring the battery back. Good Luck!-any probs, email me and I will help you |
11-17-2006, 17:13 | #20 (permalink) |
Insane Poster Join Date: Jul 2004 Location: lahore+bradford
Member: 74239 Status: Offline Thanks Meter: 0 | HI TO ALL. i just want to now witch liqued is best for pcb cleaning(wash). all my friends giving deferient sujustion. ctc lequed? spiret? alcohal? thiner? petrol? witch is the best in those? thanx to all. |
11-18-2006, 04:31 | #24 (permalink) |
No Life Poster Join Date: Mar 2003 Location: India Age: 73
Member: 23587 Status: Offline Thanks Meter: 63 | I fully endorse the views expressed by fonegeeks and Mobilerepairlog. If you do it correctly, you are more likely to be successful than fail. I think, fonegeeks is very right when he says that "DO NOT use solvents or petrol on PCB's, as it will break the board down." I may be wrong but i don't advise excessive use of CTC for this purpose. Remember, CTC damages plastic and non-metalic parts. I strongly suggest the use of Liquid Detergents used for Cleaning Watch Parts etc. My method for Treatment of Water/liquid damaged phones can be found at http://forum.gsmhosting.com/vbb/show...&postcount=173 in the thread "Training Manuals for Beginners". More related posts are also posted in the said thread from http://forum.gsmhosting.com/vbb/show...280034&page=12 onwards. Last edited by 1amigo; 11-19-2006 at 10:58. |
11-18-2006, 11:18 | #25 (permalink) |
Member: 188959 Status: Offline Thanks Meter: 7 | Nice work on the the post 1amigo, but you will put guys like me out of business . If you want to repair a fluid damaed phone under circumstances where little or no equipment is available, use alcohol [ MUST BE 100%], or nail polish remover [Acetone]. Agitata pcb in a container of alcohol for as long as you can, to remove any ingression damage fro under the I.C's. If you are using acetone , be sparing ,using a tooth brush, and then a quick dip , agitiate, and dry immediately.I don't propose you use too much acetone, but have helped people over the telephone do thier own repair in an emergency situation.Hope this helps... |
11-19-2006, 08:26 | #27 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 54
Member: 109136 Status: Offline Thanks Meter: 17 | first of all put yr pcb in alma liquide for 15 mins.... clean it and put the same nearby (6 inches up) lamp for 10 mins.. after that keep it like that till it get cold (15 mins) your pics will be ok... this is 100% solution.... from 10 out of 10 water damage pcb will work my experience |
11-19-2006, 08:55 | #28 (permalink) | |
Member: 23587 Status: Offline Thanks Meter: 63 | Quote:
However, i would like to know : (1) WHAT IS ALMA LIQUID? (2) DOES THIS PROCESS ENSURE THAT NO SALTS HAVE REMAINED ON THE PCB TO CAUSE ANY DAMAGE IN THE FUTURE ? | |
04-10-2007, 18:08 | #29 (permalink) |
No Life Poster Join Date: Aug 2002 Location: india Age: 63
Member: 14578 Status: Offline Thanks Meter: 831 | @ 1amigo, ALMA LIQUID is use for watch machine cleaning. and it is like amonia and wate and detergent mix liquid. i have no more idea what is actualy mixture of it. but it smale like amonia. so i think this. it awailable in india at watch parts shope. pink colour liquid. after use this liquid , it is good to wash pcb again with water to remove remaining detergent or solt . and then dry pcb with hot air. i use this when pcb is with much corotion or oxide . wbr wbr |
04-10-2007, 19:22 | #30 (permalink) |
No Life Poster Join Date: Jan 2006 Location: EGYPT Age: 47
Member: 217479 Status: Offline Thanks Meter: 267 | thnx for all who share their experts, & all previous solutions was for remove water from the boards when it have just been reached it, but sometime by mistake they may be still little of water hidden anywhere on the board & it will lead later for copper rust, so i need a very good solution to remove that rust, please if anyone know it to share us, thnx, B.R ... @ baraka42, is there another name for that alma liquid ??? |
How to Repair a Dead Mobile Phone | akram855 | Various CDMA/TDMA Cell Phones | 21 | 08-16-2016 12:01 |
How to Repair a Dead Mobile Phone | akram855 | Nokia Hardware & Hardware Repair | 3 | 01-11-2010 14:16 |
How to repair V360 damaged by other tool | Bi0H4z4rD | Smart-Clip | 3 | 08-11-2008 09:11 |
infitiny team, how to repair port damaged | satcomhedi | Infinity-Box | 2 | 07-21-2008 16:13 |
how to repair box damaged smcu | andres.erigure | Universalbox | 3 | 06-18-2007 13:11 |
